what transmission is in the chevy s10 blazer with a vortec v6?
Any one know.. someone said 4L60E nanother said 4L80E
Mine died and won't go forward and need to get a replacement but not sure how to tell which one I have. |
Re: what transmission is in the chevy s10 blazer with a vortec v6?
4L60E, assuming it's 93+.
1993 Olds Bravada 4.3L CPI 1999 GMC Safari SLE AWD 2002 Chevy Astro LT AWD |
Be very careful about the model year, since there have been some changes in the 4L60E over the years. The solenoids changed, the electrical connector and lines changed, and the hard parts changed. Make sure your replacement is compatible.
Other than the fact that it won't go forward, what are the other symptoms? What is the line pressure in the various ranges? Does the unit turn the driveshafts if the vehicle is raised? It the transfer case chain intact?
Permanent seat assignment on the Group W bench... Automotive Forums Survival Guide |
sorry forgot to say it was a 1995 chevy s10 blazer 4x4
Also my symptoms are as follows: truck ran fine till friday night. took truck for a drive and as I turned corner heard a loud bang ( i mean like a bolder hit the frame loud) it reved up in O/D so I put it in D ran fine down the road as I went to turn around it lost all forward gears. I still have reverse but nothing else. It will not go forward even if I shift it to 1,2,d,O/D. only movement I get is in reverse. |
Best transmission ID is to check the shape of the transmission oil pan.
Okay, it's a '95. Correct me if I'm wrong, Bowtie & MT, but a '95 is the only replacement for another '95 due to the changes, correct?
Transmission ID can be checked with the shape of transmission oil pan.
You are correct. the '95 is that special year. A '95 can only be interchanged with another '95. |
