Go Back   Automotive Forums Car Chat > Land Rover > Discovery | LR3 | LR4
Old 02-25-2012, 09:33 AM
brocsbar brocsbar is offline
Exclamation Mechanic in need!! won't start after lower intake mistake!
Ok I'm a mechanic 15 years and have my own shop and was doing a lower intake on a 96 discovery 4.0. Put small pieces of paper towels in upper intake to prevent shit from falling in. Made the rookie mistake of putting upper plenum on without removing small 3 inch by 3 inch paper towels out. (easy to do) so naturally they got sucked in the intake valves. After getting a few out with mechanical fingers I decided to take it back off and turn engine by hand until each of the valves were open and got them all out. Pulled plugs and made sure no paper was in there. Put it back together and it wont start... I did try to start it quite a bit before I realized my mistake and when I got the towels out they were fuel soaked. The crank sensor wire was broken so I repaired with butt connectors and checked continuity. Then I put sensor back in. All i can figure is either the crk sensor wires lost connection as i was putting in the crk sensor. OR "wipe-out" where the cylinders become un-lubricated from all the fuel. Although the plugs weren't very wet. But still turns kinda slow even with battery charger on it. This thing is eating my lunch and killing my brain cells. Only codes were p0150 and 1193 o2 sensor. What am I missing. I had battery disconnected and tried locking doors and unlocking with key in case of a security issue. I have to check spark today. But it did start initially and then died after paper towels choked it but i got them all out. Really could use some advice.
Old 02-25-2012, 01:23 PM
Re: Mechanic in need!! won't start after lower intake mistake!
It turned out to be the crank wires were bare down by the sensor and were touching each other. Just so everyone knows
HELP! Bravada won't start after replacing intake gasket! smiles0326 Bravada 6 09-16-2014 07:41 PM
2001 Malibu won't start after head job.. r3dh34d Malibu 11 07-09-2012 02:11 AM
3800 series 2 won't start after lower intake manifold gasket repair. tree_farmer Park Avenue 11 10-25-2011 07:34 PM
Monte Carlo won't start after replacing intake caroslmbra General Discussion 2 08-12-2010 07:03 PM
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 03:20 PM
Tags
crank , intake , start , wipeout , won't
