Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 11-26-2008, 09:30 PM
smiles0326 smiles0326 is offline
HELP! Bravada won't start after replacing intake gasket!
Help!! 2000 olds bravada. It ran fine before replacing the intake gasket. Timing was off but we fixed it, so Timing is right (at least we think. ...put it on compression stroke, TDC, then distributor lined up with the #6) thats the way the book said it should be. Afte putting it in time, it started, but had real thick white smoke that smelt like gas and eventually stalled. It won't start now unless I spary starter fluid in the intake then it runs breifly (2 sec). When we don't put starter fluid in it, it just backfires out of the intake. We replaced distributor cap and plugs. What do you suggest is wrong with it. It has spark.
Old 11-26-2008, 11:00 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: HELP! Bravada won't start after replacing intake gasket!
You might recheck the other plug wiring.
Old 09-12-2014, 07:05 PM
KChaivre KChaivre is offline
Did you find any solution to the Bravada?
Old 09-14-2014, 10:01 AM
Tech II Tech II is offline
Jumping on a 6 year old thread?
Old 09-14-2014, 07:38 PM
AF - Advisor
It was likely taken to a shop and no update given.
Are you having a problem with your Bravada?
Old 09-16-2014, 08:31 AM
I was but figured it out. Replaced the O rings on the fuel line and also had to replace the regulator. Runs like a champ now.
Old 09-16-2014, 07:41 PM
AF - Advisor
Good work!
Glad you worked it out.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
