Go Back   Automotive Forums Car Chat > Jaguar > S-Type
Old 02-23-2012, 08:02 PM
Chootem Chootem is offline
Need help with an s-type
I have a 2001 S-type v-8 4.0... I'm having an issue with a misfire. I have read all the post and chased each possible solution. The misfire is supposedly on 7 and 8 and occasionally 3. i have pulled the coil's and swapped them around 7-8 still won't fire. i have checked continuity from the PCM to each coil. Checked out ok. The other wire is ignition power which I also verified. But won't fire. i took both spark plugs out plugged them into the coil and started the car without them installed just kinda resting there. so i can see the tip of the plug. with engine running sounding like a drag car(two spark plugs pulled) I see no spark at the tip? Also tried this with brand new plugs. and with new coil. Am i doing something wrong? from what i am thinking the problem is the PCM not telling the coil to fire? Any other thoughts. I really don't wanna waste more money on this not too fix it. My wife bought it really cheap thinking her freind would take care of it and fix it. His attempt 3 cam tensioners and 2 new coils and 950 dollars later it is doing the same. So i'm not trying to throw more good money after the wrong thing again. I'm a heavy truck mechanic....don't know very much when it comes to cars and gasoline engines. Any help would be greatly greatly appreciated.
Old 02-26-2012, 01:43 PM
danielsatur danielsatur is offline
Re: Need help with an s-type
I would find a local friend with a spare ECU/PCU for your Jaguar 4.0 ,or check Ebay.
It can be bench tested, or tested in another car of same type.
vibration problem need an expert my rsx is falling apart need HELP!!! 2003rsxtypes Let's get Technical! 1 09-27-2009 05:48 PM
Need Help With Wiring Alpine Type R dual voice coils mikedeezy24 Car Audio 1 02-27-2007 01:58 PM
Help with Transmission type 73/74 Boyd57 Continental 0 11-21-2004 08:42 AM
New to site... Need help jdm integra type R cluster wiring funkyfreshdj Integra 0 05-29-2004 12:52 PM
Custom CRX WIDEBODY, Need help with rims. Need some input. Psionic '88 - '91 Civic | CRX | Wagon | Shuttlee 12 12-19-2003 12:43 PM
