Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 02-22-2012, 03:56 PM
KahneFan's Avatar
KahneFan KahneFan is offline
Tin-y sound? (with video)
Does anyone have any idea what this sound might be on a 2004 4x2 small block Tahoe LS? Not the breaks, I know that sound. I can't figure out what the deep rattle-tin sound is.
http://www.youtube.com/watch?v=wC80_BaWFmI
Poker Forum
Old 02-22-2012, 04:06 PM
DeltaP DeltaP is offline
Re: Tin-y sound? (with video)
Ah yes a GM. I've heard that sound a time or two. It's an exhaust shield rattling under the car. One of the shields around or above the catylitic converter or near an exhaust pipe. It'll usually only resonate at a certain RPM then goes away. Many times you can tweak them and the noise goes away.
Old 02-22-2012, 05:37 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
It's the heat shield above the muffler, it breaks and rattles. There is a replacement available. You can also get large worm gear clamps, like big hose clamps, that will fit around the muffler and clamp the shield, NAPA sells the clamps.
Old 03-01-2012, 09:02 PM
Joe Bough Joe Bough is offline
I had the same problem. Dealer told me that it was a loose baffel in mufler
Old 03-02-2012, 10:31 AM
j cAT j cAT is offline
Originally Posted by Joe Bough View Post
I had the same problem. Dealer told me that it was a loose bafel in mufler
it is quite possible that a baffle in the muffler is the cause . seen that before. over time this will wear holes in the muffler skin.
most times the heat shield do loosen especially if corroded. I use .030 stainless steel wire and wrap around the shields . this will out last the vehicle. no worry of the shield flying off.
86 GRand Marquis pinging sound with regular fuel jonboy64 Grand Marquis 1 02-25-2005 02:44 PM
Need Help:clicking Sound With Rpm! 1g90gsx Off-Topic 15 10-06-2004 05:06 PM
Whiny sound with AC in 2002 Grand Sport sl33pyon3 Caravan | Voyager 1 06-13-2004 12:52 AM
Squealing/Whining sound with screaching at start-up!! Please HELP!! stelyn Caravan | Voyager 5 04-27-2004 04:53 PM
