Old 09-22-2004, 07:07 PM
1g90gsx's Avatar
1g90gsx 1g90gsx is offline
Need Help:clicking Sound With Rpm!
i had ticking lifters for a while and changed the oil yesterday and it went away at idle.about a few days ago i heard a clicking with engine rpm,the more rpm the louder the clicking noise.its nots a knock like a bearing or wrist pin.does anyone have any ideas?
1990 MIRAGE HB
4G SWAP
FMIC
ACT 2100
TIAL BOV
TIAL WASTEGATE
FIC 650"s
SX AFR
MAFT
INNOVATIVE DUEL BB TURBO
TURBONETICS MANIFOLD
255 PUMP
WISECO 8:51
EAGLE RODS
DELTA 272 CAMS
SETRAB OIL COOLER
AEROMOTIVE STARLITE HOSE
AUTOMETER
ROTA CIRCUT 8"S
Old 09-22-2004, 07:16 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: Need Help:clicking Sound With Rpm!
where is it coming from? like can you hear it inside the engine bay?
Old 09-22-2004, 07:25 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Make sure it is not coming from under the car, that happen to me and it was the cat hittin the heat sheild
For Sale 98 Eclipse GS, 5 spd
Old 09-22-2004, 07:27 PM
1g90gsx's Avatar
while driving the car with the window down and then you step on it,it comes from the drivers side uder the hood.as the rpm rises it clicks faster and louder.
1990 MIRAGE HB
4G SWAP
FMIC
ACT 2100
TIAL BOV
TIAL WASTEGATE
FIC 650"s
SX AFR
MAFT
255 PUMP
WISECO 8:51
EAGLE RODS
DELTA 272 CAMS
SETRAB OIL COOLER
AUTOMETER
ROTA CIRCUT 8"S
Old 09-22-2004, 07:28 PM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Re: Re: Need Help:clicking Sound With Rpm!
Haha, the first time I read that I thought you were talking about a cat as in an animal cat . It weirded the hell out of me for the 2-3 seconds that I thought it was a cat .
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
Old 09-22-2004, 07:32 PM
EclipseRST's Avatar
Banned
does it make any noise at idle? or when you brake? try speeding up, then down shifting and see if it still makes that noise.
and your positive its not your lifters?
Old 09-22-2004, 07:33 PM
ashah000's Avatar
HAHAHAHAHAHA... that was a good laugh.
What side of the engine bay is it comin from.
Old 09-22-2004, 07:45 PM
1g90gsx's Avatar
idle:no lifter tick
letting off the gas:no clicking
it kinda sounds like a collasped lifter,it has to be in the valve train.
any ideas???????????????
1990 MIRAGE HB
4G SWAP
FMIC
ACT 2100
TIAL BOV
TIAL WASTEGATE
FIC 650"s
SX AFR
MAFT
255 PUMP
WISECO 8:51
EAGLE RODS
DELTA 272 CAMS
SETRAB OIL COOLER
AUTOMETER
ROTA CIRCUT 8"S
Old 10-05-2004, 03:47 PM
carboy1588 carboy1588 is offline
Originally Posted by 1g90gsx
idle:no lifter tick
I have the same problem. you cant hear a noise untill it hits about 2500rpms and then it makes a chattering noise. if i accelerate fast it wont make a noise untill about 3000 to 3500 rpms. and there is no lack of power at all.
Old 10-05-2004, 03:49 PM
1g90gsx's Avatar
it had to be a lifter problem because it dissapeared,no more clicking with rpm.
THANK GOD!!!!!!!!!!!!!!!!
1990 MIRAGE HB
4G SWAP
FMIC
ACT 2100
TIAL BOV
TIAL WASTEGATE
FIC 650"s
SX AFR
MAFT
255 PUMP
WISECO 8:51
EAGLE RODS
DELTA 272 CAMS
SETRAB OIL COOLER
AUTOMETER
ROTA CIRCUT 8"S
Old 10-05-2004, 03:50 PM
does yours still make the noise?
Old 10-05-2004, 04:00 PM
did you do any thing to it to make it quit. or did it just go away. and i heard if you change oil brnds it might help
1g90gsx's Avatar
its gone now but i had a feeling it was the lifters though and it was coming from the valvetrain.mine did through the whole rpm range but yours seems to be something else if you ask me.its hard to tell without hearing the car in person.
1990 MIRAGE HB
4G SWAP
FMIC
ACT 2100
TIAL BOV
TIAL WASTEGATE
FIC 650"s
SX AFR
MAFT
255 PUMP
WISECO 8:51
EAGLE RODS
DELTA 272 CAMS
SETRAB OIL COOLER
AUTOMETER
ROTA CIRCUT 8"S
Old 10-05-2004, 04:03 PM
well mine will make the noise thruogh the whole rpm range but if i accelerate fast it wont start chattering untill about 3000 rpms instead of 2500
Old 10-06-2004, 10:36 AM
kjewer1 kjewer1 is offline
AF - Advisor
I've had stuck lifters as well. I can usually narrow it down to which cylinder (bank of 4 lifters) its coming from and replace those 4. I really should replace them though, if they stuck compressed at 8k rpm they can allow the rocker (cam follower) to come off, and sometimes the cam lobe will punt it through the side of the head.
I need to change those, I just got an ulcer thinking about it... If you have really bad lifters you should change them.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
