Replacing starter solenoid contacts
It would appear that I need to replace my starter solenoid contacts on my 1995.5 rodeo. It is a 4wd Standard. 101,000 miles.
I've read where some people have removed the starter by removing a motor mount and tranny mount and jacking the engine up to get the starter out. Does this really work? I figure I can replace just the contacts and save some money. Is it possible to replace the contacts while the starter is in the vehicle but disconnected? I live in Vermont and there is no way I will be able to get those exhaust bolts loose without breaking them. I have also read that some people take the starter apart to take it out but I rather not do that if I don't have to. |
Re: Replacing starter solenoid contacts
The best way to remove the starter is to jack up the engine with a floor jack and a piece of wood to protect the oil pan. Unbolt the motor mounts on both sides by going through the wheel opening. Taking apart the starter isn't a good idea. Leave the tranny mounts alone.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs. 03 GMC Envoy XL SLT 4x4 5.3L V8 |
| The Following User Says Thank You to Cat Fuzz For This Useful Post: | ||
sdsisuzu (02-23-2012)
I see you have a lift kit on your Rodeo and I do not. Did that make a difference for you being able to remove the starter by jacking up the engine?
No. I only have a small 2 inch suspension lift.
So I ordered a solenoid contact kit - $13.00 shipped to me. Includes the contacts and plunger.
Is it possible and maybe easier to just replace these without removing the starter? If I recall, I replaced these on a 2000 dodge caravan I had once and the only contact that was bad was the negative one. I did it without removing the starter from the engine. |
I really doubt you can get enough access to do it with the starter in place. Dodge Caravan starters practically change themselves, they are so easy to get to.
