Old 01-24-2010, 01:17 PM
sgusmeri sgusmeri is offline
1996 Grand Am 3.1; No Power to Starter Solenoid/Relay
Checking power from the ignition down and can't find Neutral Safety Switch; can anyone tell me how to get to it?
Any other ideas welcome as well:
Key turns, gears shift, lights on, will not start. No clicking, nothing. Almost like the battery is dead but it's not; it's brand new and I took it back to have it checked just in case.
Old 01-24-2010, 01:24 PM
jd-autotech jd-autotech is offline
Re: 1996 Grand Am 3.1; No Power to Starter Solenoid/Relay
make surre your in park, even if you shift the shift all the way down then back to park
Old 01-24-2010, 01:25 PM
check connections at both ends of battery cables
Old 01-24-2010, 01:41 PM
danielsatur danielsatur is offline
Check for uniform + nonuniform corrosion on copper, it will look blueish or green in color.
Copper corrosion could add resistance and drop a voltage, some of the battery will be lost going to the starter.
We have seen batteries, starters, and alternators replaced premature, because of bad cables.
Old 01-24-2010, 01:45 PM
u can also check for a manual at your library for componet location
Old 01-25-2010, 01:28 AM
3100 3100 is offline
Banned
Find your power booster then look down on the transmission right in front of the power booster, (when you look down) you will see NSS it is black and is about 2x1 inch in size with connectors on two opposite sides, and shifter linkage connected to it.
Old 01-26-2010, 12:42 AM
Banned
in this case you can start in reverse order: see if your starter solenoid is getting powered when someone is cranking for you, this will save you a lot of time.
Tags
1996 , grandam , solenoid , starter
