Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 02-21-2012, 02:11 PM
dpj52190 dpj52190 is offline
Send a message via MSN to dpj52190 Send a message via Yahoo to dpj52190
05 corolla surpentine belt making noise at cold start
Hi I was wondering because surpentine belt is a big thing for 05 corolla since everything runs on it. I also had a 94 camry which had a alternator connected to a belt. and if i wanted to tigthen up that belt i would just loosen the alternator and pull it. Is there a way to tighten up supentine belt in my 05 corolla in the same way?. I would like to get a new belt but running short on money. please advice an alternative
Old 02-21-2012, 10:44 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 05 corolla surpentine belt making noise at cold start
Find out which pulley is making the noise and potentially has a bad bearing. Replace the accessory with the bad bearing.
You can test the tensioner and see if it is within spec. Then replace it if it is not in spec.
No way to adjust the belt tension.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
93 lesabre makes noise after starting cold sjaje LeSabre 0 04-30-2008 06:43 PM
Surpentine Belt - Proper installation? Gary99Classic Cherokee 3 08-14-2007 03:08 PM
belt making noise rice(er) Engineering/ Technical 6 05-25-2006 11:51 AM
Surpentine belt change on '97 Riviera rivyera Riviera 1 01-30-2006 07:19 PM
Belt noise on cold start optihead Grand Cherokee | Grand Cherokee SRT8 1 12-16-2004 01:57 PM
