Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Firebird Discussions
Old 02-19-2012, 10:43 AM
stilts07 stilts07 is offline
2000 Firebird headlight grinding sound.
My headlight motor works fine until you turn the light off and it makes this grinding sound for like 5 seconds. I don't think i need to replace the motor because they come up and down just fine. Any suggestions???
Old 02-19-2012, 03:24 PM
Tech II Tech II is offline
Re: 2000 Firebird headlight grinding sound.
Well, you have two motors.......is it one side that is making the noise?
Old 02-19-2012, 06:29 PM
the passenger side
Old 04-03-2012, 07:36 PM
jjchevy jjchevy is offline
its the gear mine did the same thing look here
http://www.bfranker.badz28.com/headlightfix/index.htm
Old 04-03-2012, 07:39 PM
The gear is the nutorious weak link the motors dont usually go bad they are beefy if you you plan to keep the car get the one on the link i sent WELL WORTH IT or if you want cheap you can find plastic on ebay but they don't last long either way the link has great instrucions.
Old 09-25-2014, 10:17 PM
BruceWayneClark BruceWayneClark is offline
I had to replace the gears inside the motor drive housings. when it makes that
sound, it is the stripping of the nylon or plastic gears inside the housing.
the worm gear has stripped the plastic gear. after replacing the plastic gear, it happened again and i finally went on ebay and found a brass replacement gear and have not had the problem since. replacing those gears are a pain but when you take out the motors, pay attention to which way the mounting bolts go. 1 goes one way and 2 go the other way. if you don't get them right, they will catch on the linkage when you turn on your lights. Very important to clean all the old glue off the gear housing when you take them apart and replace with new 2 part epox. I did mine 3 times to get them right.
Squealing sound coming from right side olopezm Windstar 5 08-26-2010 05:32 PM
Slight Grinding Sound When Braking spyder_m_2000 Sierra 0 07-06-2010 08:47 PM
2000 Ford Mustang Grinding Noise While Idling Starbucksinhand Mustang Problem Diagnosis 1 02-03-2010 01:59 PM
2000 Firebird headlight question Cbierniat F-Body Problem Diagnosis 2 12-27-2008 11:47 AM
Grinding sound coming from front of 2000 Pontiac Grand AM GT jeffreno Grand AM 7 04-06-2004 02:27 PM
