Old 02-19-2012, 10:07 AM
msmith69oldz msmith69oldz is offline
Heater bypass elbows! HELP!
Hi all! I have a 99 Grand Prix GT. 120,000 miles. Upper and lower intake gaskets and upper plenum done last year. These plastic elbows that run from the alternator bracket keep leaking! I have replaced them 3 times in a year. I have cleaned and cleaned the ports that the elbows go into each time I replace them but after a few weeks they leak again. Can i put some kind of sealant on these elbows to prevent them from leaking? Hi temp RTV or something? Will sealant cause more problems than replacing them all the time? Thanks for any responses!
Old 02-19-2012, 04:17 PM
Tech II Tech II is offline
Re: Heater bypass elbows! HELP!
Are you talking about the elbows that attach to the heater core hoses?
If so, I would go to a dealership and get the OEM o-rings that go on them.....
Old 02-19-2012, 06:26 PM
Its the 90 degree elbows that go from the alternator bracket to the manifold and the water pump. I think after doing some searching that its probably because I used the HELP brand elbows and not the GM elbows from the dealer. I went ahead and put Black RTV sealant on the elbows for now but if it doesn't work I guess I will be replacing them with the GM brand elbows. Thanks for the response though Tech II!
Old 02-19-2012, 10:01 PM
Think I read somewhere where there was a problem with those....don't remember if it was the elbows or the o-rings that were the problem......black RTV is not the answer, because of the expansion and movement of the elbows.....
Cooling System Bypass Elbows for SII 3800 Engines BNaylor Tips and Maintenance 2 10-25-2012 09:14 PM
Tensioner Assembly Removal for SII 3800 Engine and Bypass Elbows '99 and Up BNaylor Tips and Maintenance Procedures 16 10-01-2012 07:03 PM
Main Drive Belt Tensioner Removal Procedure and Bypass Elbows '99-'03 BNaylor Tips and Maintenance 5 10-25-2008 07:56 PM
Coolant Bypass Elbow and Tensioner Problem RichBrew General Discussion 12 09-07-2008 04:51 PM
How do you replace the Heater Water Bypass elbow? guitarfish Grand Prix 12 05-13-2007 10:38 AM
