Old 02-18-2012, 02:59 PM
SamNovice SamNovice is offline
vacuum to EGR
I have 1998 windstar 3.8L. It runs fine, but lately the idle has been rough. I pulled the vacuum line to EGR and that fixed the rough idle problem. I noticed that there is a slight vacuum in the line while idling. Is this normal??? How is the vacuum to EGR controlled? Shoud I replace EGR valve? Suggestions would be very appreciated.
Old 02-18-2012, 05:40 PM
wiswind wiswind is offline
Re: vacuum to EGR
It is NORMAL for there to be a slight vaccum in the hose to the EGR valve at idle.
The EGR valve is not known for being a high failure item.
The 2 most likely causes of your problem are clogged EGR ports in the lower intake manifold and the EGR flow sensor, aka DPFE.
The EGR flow is through a pipe that goes from the front exhaust manifold to the IGR valve, which is mounted in the lower intake manifold.
The flow then goes to each cylinder's intake through the lower intake manifold and enters each intake flow through a small 1/4 inch hole.
The EGR ports clog right at the end.....right where they enter the main airflow.
What normally happens is that these ports clog more on the driver's side first.
This ends up with the 2 ports on the passenger side being the last ones open...and all the EGR flow is now going to 1 or 2 cylinders.....starving them of oxygen.....causing the misfire.
To clean the EGR ports in the lower intake manifold, you MUST remove the upper intake manifold.
Then, it is easy to clean each port.
Use care to avoid getting any fluid or dirt, etc down the intake ports that go to the cylinders.
A small screwdriver and shop vac are excellent tools for the cleaning.
This picture shows the lower intake manifold, with the upper intake manifold OFF.
A closer look at a couple of clogged ports
The gaskets on the bottom of the UPPER intake manifold are reusable.....they are shown in this view of the bottom of the upper intake manifold.
The DPFE (EGR flow sensor) is also a common failure item.
It is easy to change.
The 2 hoses going to it are slightly different sizes, so you will know if you try to switch them.
In the picture that I am posting, mine is the "old grey style" the newer style is black.
The DPFE sits right out in front, so you don't have to remove a bunch of stuff to change it.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 02-19-2012, 06:51 AM
snshddog snshddog is offline
Re: vacuum to EGR
I have had that same problem, fixed it by spraying a bit of intake cleaner in the line with the engine running. afew short sprays and it fixed mine.
Old 02-19-2012, 08:52 PM
Re: vacuum to EGR
Thanks, Wiswind. Since my egr ports were cleaned not long ago, I'll try to see if my dpfe is any good.
Old 02-19-2012, 08:54 PM
Re: vacuum to EGR
snshddog, which line did you spray, the vacuum line to EGR???
Sam
96 Intrepid EGR valve meltdown ccundy Intrepid 3 07-28-2010 06:23 PM
92 Pont 3.4L Vacuum/EGR/AC Problem ronkay Grand Prix 5 04-11-2008 10:08 AM
EGR valve, EGR sensor jbgood F Series 2 11-17-2006 09:10 PM
EGR Cleaning -> EGR insuff. flow engine code? mlingk Trooper | SLX | Bighorn | Wizard 7 02-16-2005 11:43 AM
vacuum leak? egr? eexhaust? Chard18 Escort 1 05-17-2004 02:43 PM
