Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 02-17-2012, 09:25 AM
Tapout417 Tapout417 is offline
01 Denali whirling noise coming from front differential
I have a whirling or spinning noise coming from front differential at speeds above 30 mph. The noise stops when I release the accelerator, anyone have this issue? From what I read maybe the bearings, any info please help
Old 02-17-2012, 09:29 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 01 Denali whirling noise coming from front differential
Sounds like you have a noisy pinion bearing. You should replace pinion and carrier bearings at the same time. Its aslo possible the ring and pinion gears are noisy. The only way to tell for sure is to disassemble and inspect it all.
The Following User Says Thank You to gmtech1 For This Useful Post:
Tapout417 (02-17-2012)
Old 02-17-2012, 01:00 PM
Ring and pinion have to be replaced, so its in the shop now,
Thanks
99 Malibu LS LOUD metal noise coming from front right side... TheBU Malibu 7 09-12-2007 01:19 PM
1990 Runner with Noise coming from front krc333 4Runner/GX470 16 12-10-2005 07:53 AM
loud rotational noise coming from front-end CareyPJ GS300/GS400/GS430/Aristo 2 07-21-2005 02:52 PM
squealing type noise coming from front wheel bribella Windstar 7 03-30-2005 05:20 PM
grinding noise coming from front when in motion, when wheel's turned left it goes! caramel star Clio/Clio II/Clio III 2 03-14-2005 09:50 AM
