Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 02-17-2012, 05:35 AM
virgamanda virgamanda is offline
Send a message via AIM to virgamanda
Front Hub Removal Question
My 03 Explorer 4X4 front left wheel is roaring only when I round a curve or turn. I assume this is the bearing. In order to get the hub off, will I need a special tool to separate it from the cv shaft.
Old 02-18-2012, 07:15 AM
big white bufflo big white bufflo is offline
Re: Front Hub Removal Question
no special tool is needed just the socket for the hub nut you can rent this from autozone or other parts place the bolt come in from the back of the spindel put can be remove by pushing the shaft in and turning the spindel to one side then take a hammer to pop it loose from the spindel about 1hr half job for novice wrench
Last edited by big white bufflo; 02-18-2012 at 07:16 AM. Reason: added nut in sentence
2000 front hub removal ford50 Durango 2 11-11-2006 09:46 PM
Front Hub removal...HELP ME!!!! please. HmbrgrRdr Bronco 1 01-02-2006 06:45 PM
1992 Trooper 4WD Front Hub removal davex13 Trooper | SLX | Bighorn | Wizard 2 09-11-2005 01:54 AM
F-250 4x4 Front HuB Removal help jkcrewsn F Series 2 05-15-2005 11:39 PM
front hub removal timguyli Metro 3 04-04-2005 07:27 PM
