Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 07-29-2004, 04:48 PM
davex13 davex13 is offline
Exclamation 1992 Trooper 4WD Front Hub removal
Need to replace rotors on front. Never did one with auto 4WD hub in front of rotor. Removed wheel, caliper, took off bolts that attach rotor to front of hub (6xBigger bolts). Remove 6xsmaller bolts that keep 4WD hub cover in place, pulled that off to discover greasy washers and springs, no clue, what now. Do I need a special tool, how do I remove these washers and springs to get to the spindle nut, I suppose.
Old 09-13-2004, 12:18 PM
georgiatrooper georgiatrooper is offline
I had the same problem. The sorry Chilton's conveniently skips how to use the spindle tool to remove the hub.
Did you figure it out? I'd sure like to know how to remove the hub.
thanks
Old 09-11-2005, 01:54 AM
mike082679 mike082679 is offline
Re: 1992 Trooper 4WD Front Hub removal
thanks
Try this link: http://www.arizonatools.com/catalog/.../detail/12307/
