Old 02-15-2012, 07:55 PM
chris_8222 chris_8222 is offline
problems with dash lights
at first the dash lights worked off and on.now they have totally stopped working.i have checked all the fuses and bulbs and they all look fine.im running out of ideas so if anyone has an idea i would greatly appreciate the help.oh yea it is a 97 if that makes a difference.
Old 02-16-2012, 07:54 AM
Schurkey Schurkey is offline
Re: problems with dash lights
Dash lights dimmed with the headlight switch?
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
The Following User Says Thank You to Schurkey For This Useful Post:
chris_8222 (02-16-2012)
Old 02-16-2012, 10:51 AM
Tech II Tech II is offline
I agree....with the lights on.....adjust your dimmer switch....watch the cluster, the radio and HVAC head......if none work, check the dimmer circuit.....if the radio and HVAC work, but the cluster doesn't, then you may have a cluster problem....
The Following User Says Thank You to Tech II For This Useful Post:
Old 02-17-2012, 06:48 PM
none of the lights work when adjusting with the dimmer switch.i even tried switching the cluster and still nothing.
Old 02-17-2012, 09:51 PM
If the lights did not change on the radio and HVAC control head, the dimmer circuit has to be checked...
Old 02-18-2012, 05:41 PM
where do i find the dimmer circut?
Old 02-20-2012, 12:06 PM
rkvons's Avatar
rkvons rkvons is offline
You have a switch to manually turn your headlights on. Next to it is the little roller-type switch that adjusts the brightness of your dash lights. If you move that switch all the way to its brightest level and beyond, it should light up your dome light. That little roller switch is basically your dimmer circuit.
Old 02-21-2012, 08:17 AM
oldblu65's Avatar
oldblu65 oldblu65 is offline
If none of the dash lights are working , you likely have a bad headlight switch .
" Sometimes I grow so tired "
The Following User Says Thank You to oldblu65 For This Useful Post:
chris_8222 (02-26-2012)
Old 02-26-2012, 03:08 PM
thanks for the idea to replace the headlight switch.just finished replacing it and all my lights work.
Problem With Dash Lights jiggy2dmax Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 02-20-2005 01:07 AM
New 99 Camry owner with dash light questions, thanks max gurth Camry/Camry Hybrid/Vista 1 11-28-2004 11:12 PM
Problem with dash lights laurenz433 Sonoma | S-15 1 08-07-2004 08:33 PM
Help with dash lights and instrument panel brandon92484 Sonoma | S-15 2 05-27-2004 02:15 PM
Problems with Dash lighting in 91 Century Wolfjr Century 1 02-13-2004 04:19 PM
