Old 02-15-2012, 06:47 PM
1996ctnc 1996ctnc is offline
99 k3500 lS
Power door locks and keyless entry don't work. The keyless entry only locks the drivers side doors. Is there some kind of body control module or something simalar? If so need to find where it is located. I got a haynes book and can't find it in the electrical section.
Old 02-16-2012, 08:08 AM
j cAT j cAT is offline
Re: 99 k3500 lS
what body style do you have ? the problem is the keyless entry will only lock the drivers door ? all other door fuctions are inop ?
first start by checking all fuses with a meter. relays are used to do this operation and possible BCM. could be bad wirings and or actutators.
if this occured suddenly a blown fuse which would indicate a bad wire shorting. this is difficult.
the haynes book is incomplete. you may have to subscibe to a internet repair like alldata.
Old 10-15-2013, 01:19 AM
Re: 99 k3500 lS
It is an early 1999 K3500 ls crew cab. The key less entry will unlock both front doors and drivers side rear door, but will only lock both drivers side doors. the switch on the inside master control panel on drivers door will do nothing as far as the electric locks go but the window switch works fine for all windows.
Door Speaker Install On a 2000 K3500 tubjub C/K 2 10-11-2004 12:41 PM
Going to by a K3500 gschretter C/K 5 09-06-2004 08:15 PM
VIN number decifering and K3500 questions markf C/K 2 07-05-2004 03:51 PM
1990 K3500 Front Rotor Removal Cpr2004 Automotive News Desk 1 06-19-2004 10:38 PM
Fuel tank problems, K3500 conley C/K 1 01-21-2004 06:10 PM
