Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 02-15-2012, 12:42 PM
harrison903 harrison903 is offline
95 camaro 3800 ignition/starts and dies
I have a 95 camaro. When I turn on the ignition all the gauges come on but the ignition will not engage the starter. I can cross the starter and start it but it dies after about 2 seconds. Can someone please help?
Old 02-16-2012, 10:37 AM
Tech II Tech II is offline
Re: 95 camaro 3800 ignition/starts and dies
Do you have a black resistor on your ignition key?
If yes, turn key to "on", don't crank.....look at the SECURITY light in the dash,,,,should come on for 5 seconds and then go out.....if it STAYS ON, you have a PassKey problem.....the usual problem is that one of the wires to the lock cylinder has broken.....can be checked by reading the resistance of the key, and then installing key in lock cylinder, and then disconnecting the two wire harness in the steering column and reading the resistance at the disconnected harness.....if you get an "OL" reading, one of the wires to the cylinder is broken.....can be fixed by replacing the lock cyinder and key(big job), or getting a resistor with the same resistance as your key and attaching it to the wire harness connector(other half going away from the column)....
Auction's site ignition modules? jarl Trans Sport 4 04-25-2010 03:33 PM
99 Suburban starts and dies, starts, backfires, dies again crazy4mylilbaby Suburban 3 08-04-2008 12:20 AM
91 camaro starts and dies jasonmarie F-Body Problem Diagnosis 3 06-19-2007 12:08 AM
no start, start and die Grand_man Grand AM 1 04-11-2005 07:46 PM
Jeep Cherokee 89' Turns Over but dies, eventually starts and dies while driving. forester6779 Cherokee 2 12-24-2004 01:16 PM
