Can I swap VCM
I have a 1999 s10 and a 1998 blazer. I need to check a VCM. The numbers do not match up on them. What will happen if I take the VCM from the S10 and put it in my blazer that has less miles.
Re: Can I swap VCM
Why are you wanting to swap? Would it be to change milage?
Re: Can I swap VCM
No I have been trying to figure out a P0740 you can read in other post's that I had. I did all the testing and I am at the point where it says get a new VCM.
I can get a new one for $90 but then I need a relearn on it. I just did not want it to be good and waste the time and money. Chevy can test my current VCM for $100 but I dont know what I should do. I can make my tcc engage with a ground wire and toggle switch. I know that the POS wire is good but it is just not grounding. Either wire or VCM is not telling it to ground. Should I check something on my brake pedal switch or is that related to the power side of the TCC. |
Re: Can I swap VCM
If you get down to needing a VCM then buy one and get it programed for your vechical.
| The Following User Says Thank You to MT-2500 For This Useful Post: | ||
FishFind (02-15-2012)
Re: Can I swap VCM
Yeah that is where I got to. I had a GM tech email me the repair chart and I am at the part where it says get a new VCM.
