Old 02-22-2005, 09:37 PM
Lahardbodie Lahardbodie is offline
Is there a stronger engine I can swap out my 420a with?
Ok guys I have a 95 GS with 115k and tons of show mods like 19" rims, bomex body kit, system, lots of chrome under the hood, undercar neons, and so on. But now I'm wanting more horsepower. ]Now instead of spending $8k on rebuilding with better internals and putting a HRC stage 2 kit on and all that I've been watching Overhaulin on the speed channel a lot and been seeing how you can order all these crate engines. Is there any other stonger engine like say an EVO engine as an example (as I know that wouldnt fit) that I could buy new straight out of the box and put in place of my 420a motor? That way I wouldnt have to fool with rebuilding and turboing and all. thanks
LA.
Old 02-22-2005, 09:41 PM
Raz_Kaz Raz_Kaz is offline
Re: Is there a stronger engine I can swap out my 420a with?
Sure one of the Evo's engine can fit the DSM.
4G63 baby!
Old 02-22-2005, 09:43 PM
P.s.
Please do not sugguest the 4g63 as I already know what a large amount of trouble and expense it would be to attempt doing. thanks
LA.
Old 02-22-2005, 09:47 PM
unless it's custom made, good luck finding one that will fit perfectly witrhout any moving around
Old 02-22-2005, 10:07 PM
jose02907 jose02907 is offline
i want
Old 02-22-2005, 10:17 PM
Unhappy engine swap from 1990 talon awd turbo
i want to swap my engine with awd turbo from a1990 talon to a1992 to1994 hyunday elantra but im wondering if its posible to swap also the awd to the elantra will it fit
Old 02-23-2005, 04:18 AM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
the elantra isn't made with the clearances and mounting points that would make AWD a reasonable conversion. For example the rear differential would interfere with the fuel tank. If you were to convert a DSM you'd just get an AWD DSM fuel tank, but there is no such thing for an Elantra so you'd have to run a fuel cell in your trunk.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 02-23-2005, 02:39 PM
mitsu_eclipse95gst's Avatar
mitsu_eclipse95gst mitsu_eclipse95gst is offline
ok slow boy racing has build motors for the 420a if thats what you are looking for.. http://www.slowboyracing.com/Race_Engines.html
hope that help you some
1990 Mitsubishi Eclipse GSX
1995 Mitsubishi Eclipse GS-T (SOLD)
2002 VW Jetta 1.8T
Old 02-23-2005, 02:57 PM
AngelOfNight 9's Avatar
AngelOfNight 9 AngelOfNight 9 is offline
Re: P.s.
LA.
My homeboy and I just swapped out his 420A from his 97 RS with a 4G63T from a 94 GS Turbo. It's not as hard as you think, we just had to change the ECU, the speedometer, and the motor mounts had to be changed. Welded in a new Clutch pedal with little minor odds & ends and we were straight.
*91 TSI AWD*
Old 02-23-2005, 03:05 PM
tranny is on other side how did you get the mounts right? if it was easy PLEASE PLEASE make a site on it with pics so every one else can do this there is at least 1 a week asking this
2002 VW Jetta 1.8T
Old 02-23-2005, 03:17 PM
Re: Re: Is there a stronger engine I can swap out my 420a with?
We plan on opening our own site up next year but in the mean time, I will post pics of my 91 TSI AWD with pics from when I first bought it smashed up and the motor all yellow and black with pics of me changing everything around. I'll post pics of his car from before and after as well. When we're done with the body There might be a pic with me bitchin from being frustrated here and there though. lol I'll post a pic of my whole team this spring.
*91 TSI AWD*
Old 02-23-2005, 07:26 PM
macder macder is offline
Send a message via MSN to macder
I think we want to see this 2G RS w/ a 4g63, not your 1G w/a 4g63. And if you did do this, then you are somewhat retarded since selling the RS, and using the money you would have used for the swap, would of got u a 2G 4g63 DSM. Not to mention you'd probably live longer.
BTW, Your "Homeboy" sh*t has to stop, it say's alot about your general intelligence level. I'm sick of reading your retarded post's.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 02-23-2005, 07:58 PM
imtheoneandonlyD's Avatar
imtheoneandonlyD imtheoneandonlyD is offline
Send a message via AIM to imtheoneandonlyD
I believe you can swap a sebring motor into the rs/gs. But im not 100% on that.
Pictures of the Truck
Old 02-23-2005, 08:34 PM
Would saying "my friend" suit you better? Were you brought up in the back hills possibly? As for intelligence, I majored in Criminal Justice. After I finish MOS training next year I'm going to UTI for a year. You're ignorant to judge someone by saying one solitary word "homeboy" Is it too ghetto for you? Possibly because you're from Canada, ay?
As for our swap, you made little sense on what you had posted.
'My FRIEND' found a 94 GS Turbo Eclipse for $500 at an auction to use the motor and tranny for his 97 RS. He also sold his stock 420A for 500 afterwards to some other guy who shot a rod right threw his oil pan and was searching for a quick swap. As for living longer, the car is a hell of a lot safer now than it ever would've been stock. The only one retarded is you. "Yet another example of someone with a smart comment when I'm minding my own business posting.. because he doesn't care for a word I use periodically & doesn't believe we did a swap for as cheap as we have"
*91 TSI AWD*
Old 02-24-2005, 03:13 AM
^ i wasnt brought up in the hills and it annoys even me. But maybe thats cause im from MN ey? Im sure we dont know your ghetto-fab ebonics.
