Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 02-14-2012, 10:11 PM
minitrucker minitrucker is offline
22RE fuel pump pressure?
So i bought myself an aftermarket Fuel cell, i'v already replaced the GM sending unit. I don't want an internal fuel pump but since its EFI I need to know the Pressure so I can swap it out.
Does anyone know what it is? Or how to find it?
any help would be much appreciated.
Thanks
Old 02-14-2012, 10:27 PM
Re: 22RE fuel pump pressure?
nevermind i found it after a while of digging around. For those of you that don't know its
"Fuel pressure
Fuel pressure plays a big role in the operation of a fuel injection system. Because the injector is essentially a gate valve for fuel delivery, increasing fuel pressure can allow you to cram more fuel into the intake tract for a given injector pulse width. Typical fuel pressure for a stock 22RTE engine is 43 psi. The maximum fuel pressure that the stock injectors can handle is about 70 psi -- above that and the injector begins to fight the fuel pressure to get its valve open, and fuel deliver actually decreases in volume.
Fuel pressure is determined by both the fuel pump and the fuel pressure regulator. The stock fuel pressure regulator has a hose that connects it to intake manifold vacuum/pressure, so that as manifold pressure rises, fuel pressure also rises, typically by a 1:1 ratio. The pump determines the overall volume of fuel that the system is capable of delivering to the injectors. The size of the fuel lines can also be a limiting factor if fuel demand is significantly greater than stock."
Old 02-17-2012, 08:47 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Good to know, thanks.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
96 Tahoe Fuel Pressure Issues mcmyket Tahoe 3 09-17-2009 09:09 AM
Fuel pump pressure?? Celicagts64 Celica 14 02-04-2005 08:24 AM
fuel pump pressure rockwild Blazer 3 01-16-2005 03:17 PM
fuel pump pressure rockwild S-10 2 01-14-2005 09:52 PM
Fuel Pump Pressure Yur0k Performance 0 08-26-2002 03:55 AM
