Old 02-14-2012, 12:04 PM
Pat Hodges Pat Hodges is offline
2005 Silverado heater
Truck heats up fine while it is in park and idling. When you put it in drive, the temperature gauge starts dropping and blows only cold air in drive. I replaced the thermostat but it continues to do the same thing.
Old 02-14-2012, 01:10 PM
maxwedge maxwedge is offline
A990 racer
Re: 2005 Silverado heater
If this is a Silverado pick up this is the wrong forum, seems so. I am moving this to the Sil. forum above in the trucks.
The Following User Says Thank You to maxwedge For This Useful Post:
Pat Hodges (02-14-2012)
Old 02-14-2012, 04:12 PM
j cAT j cAT is offline
my guess is the coolant system needs to be burped.
start cold engine . remove coolant cap add coolant to the cold fill mark . rev engine to 2,ooo rpm every 2 min . repeat until engine is at normal operating temp. this is how the coolant system is purged of air.
whenever coolant is replaced/changed you remove the heater core hoses from the engine. then you flush out the heater core in both directions until the flow is clear and unrestricted.
always use dexcool at 60% to 40% distilled water. 2 to 1 ratio will give max protection and with these engines you need it.
replace every 3-4 yrs not 5 years.
Old 02-14-2012, 04:19 PM
Thanks. I will give it a try.
Old 02-14-2012, 07:44 PM
post back how it went. if air is in the system you will need to add coolant for sure. air bubble is usually in the heater core.
if this is not correcting this, it may mean some expensive repair work is required.
Old 02-15-2012, 01:23 PM
It worked! Thanks again for the help.
Old 02-15-2012, 02:18 PM
thanks for the feed back . goodluck.
97 k1500 z71 silverado, BLOW THE HEATER CORE???? kokopelli85 Silverado 6 01-12-2010 08:38 PM
2005 Silverado front end converison on 2000 Silverado Oscar_grouch Silverado 3 03-18-2007 04:37 PM
2005 Silverado 2500HD phyerftr Silverado 2 01-27-2005 07:24 AM
87 Silverado heater core dieselfumez C/K 0 12-29-2004 05:10 PM
99 Silverado, Heater Not Working volcano_joe Silverado 7 11-03-2004 09:31 PM
