Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 02-13-2012, 10:47 PM
SportsPhotog SportsPhotog is offline
03 Eoy Windshield Washer Fluid pump leak
I've been losing my windshield washer fluid recently, pulled the aircleaner assembly out to access the resevoir and found that what appears to be a main pump that goes into the resevoir that feeds to smaller pumps, one for the windshield and one for the headlights.
The 2 smaller pumps appear to be identical, the larger one that goes into the tank is totally rusted/rotted out. I can't seem to locate a part number and all I can find at the local parts stores are the smaller individual pumps. I can run to the dealer but due to cost, that is my last resort.
Anyone have any ideas what this larger main pump is called and how do I go about getting a new one?
Thanks in advance!
Old 02-14-2012, 06:49 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 03 Eoy Windshield Washer Fluid pump leak
The two identical ones are the pumps for the front and rear washers, the oddball one is for the headlamps.
The Following User Says Thank You to gmtech1 For This Useful Post:
SportsPhotog (02-14-2012)
Old 02-14-2012, 10:57 AM
Thanks, that makes sense. Only thing I was a bit confused on is that the headlamp pump is the one that is tied into the resevoir, not sure but I think it also feeds the front and rear window ones.
Windshield washer fluid pump-06 Malibu Enemy459 Malibu 0 12-12-2010 10:21 AM
Windshield Washer Fluid Pump Problem stcolympia F Series 1 01-21-2010 06:20 PM
Windshield fluid pump usrolo Envoy 0 11-05-2009 02:53 PM
Windshield Washer Fluid Leak phewop118 Intrigue 3 06-10-2007 03:46 PM
98 windshield washer fluid will not pump jordanm Intrigue 1 01-17-2004 03:26 PM
