Old 01-07-2004, 08:53 PM
jordanm jordanm is offline
98 windshield washer fluid will not pump
Hello,
Just wondering if there is a fuse for the winshield washer pump.
Mine just quit on a muddy morning drive to work. If there is not a fuse for the pump, how hard is it to change the pump?
Thanks in advance
Old 01-17-2004, 03:26 PM
promiscuousman promiscuousman is offline
The washer fluid pump will easily be changed. My mom's intrigue wasn't pumping fluid up to the window, so I looked under the passenger side wheel well and found that the pumphad just kind of popped off somehow. I don't remember if I removed the plastic from the inside of the wheel well or not? but even if I did that's easy enough. Once you look under the passenger side right infront of the wheel, you will see the pump just snapped in the bottom of the resivour. check it out
good luck
cory
2000 GMC Sonoma Will Not Start Without Starting Fluid aserapiglia General Discussion 10 01-29-2011 10:27 AM
Windshield washer fluid pump-06 Malibu Enemy459 Malibu 0 12-12-2010 10:21 AM
Windshield Washer Fluid Pump Problem stcolympia F Series 1 01-21-2010 06:20 PM
windshield washer fluid doesn't work right dmorlow Aurora 9 03-23-2004 12:34 AM
