Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 02-13-2012, 04:05 PM
Eriedipper's Avatar
Eriedipper Eriedipper is offline
Smile A "temporary" fix for the Jimmy Heater problem
I'm the owner of a 99 Jimmy, whose heater is on maximum heat. A common problem judging by the number of Jimmys/Blazers driving around in winter with their windows open!
As a temporary relief from the heat, I've found if you activate the "re-circulate" mode button, it will stop the flow of hot air!?! Note: In order for the "re-circulate" mode to come on, you must have the air flow directed to either your feet, vent or vent/feet.
A few minutes of driving with this switched on in a Canadian Winter, you'll be glad to switch it off occasionally! Good luck.... Roger
98 Jimmy heater problem, noise behind glove box pitbullvassar Problem Diagnosis 3 06-03-2009 10:59 PM
The fix for the clunk?? spackelman Silverado 0 02-06-2007 08:54 PM
Another fun fix with the Jimmy JimmySLS Jimmy 3 03-21-2005 02:04 PM
2001 Jimmy heater problems Jimmy2001 Jimmy 2 02-05-2005 01:01 AM
2000 jimmy heater problem dmoney002611 Blazer 0 01-05-2005 11:18 PM
