Old 02-12-2012, 02:47 PM
Sonomaturn2 Sonomaturn2 is offline
Trumpeter GT40
A race program born out of resentment. And a $20 million resentment in the 1960's no less!
Greetings! I've already been working on this for a while and finally decided to create a post. My goal is to use most of the kit but add a few things mainly from styrene and turned/ machined metal. I've read quite a few reviews and critiques of Trumpeter's kit. I agree with some of the criticisms but also totally disagree with others. I'll explain later.
And a one, and a two......
I removed all the parts from their sprues and grouped them based on their location on the car. Yes, there's a ton of parts that needed, in my opinion, the chrome finish removed. This was one of first things I did. I then assembled the whole model using thinned white glue, dismantled and soaked all parts in warm soapy water. This really helped me decided where and how much detail I wanted to add.
From the get go, I knew I wanted the front clip to clam-shell. Before I started modifying anything, I sat down and drew some ideas on paper and decided on a plan of attack. I discovered the most important thing was to identify where it would pivot. I put the tires/ wheels on and located where everything would attach. The challenge is the pitch of the nose. Too far back, the nose will bottom out before the clip is all the way open.
The black, inner walls assemble underneath-
I made catches from styrene and attached them at the front of each piece then test fit each one temporarily installed. Each one had to be sanded down to match the curved profile of the nose bottom.
Then, I marked where to drill holes so rod could be inserted underneath the location of where the radiator will go-
Next, on to the rear clip, errr, the bonnet, I guess...... After test fitting, I realized I needed to pull out the hair dryer-
The problem is it doesn't want to sit very well. This was probably my biggest issue with this kit. I didn't like the fact it didn't sit flush and there isn't anything that it clasps to like on the real car. The kit latches are a part of the chrome tree, they're glued to the bonnet. I decided to machine latches from aluminum and kill to birds with one stone.
The latch bases were made from brass. The latch and base were connected using music wire soldered in place. Also, the rear was modified so there was room for the base to be attached.
Lots of test fitting, many choice words, about 40 bullets bitten and...........
Latches catch music wire now embedded in the body all around. Also, fully open-
Cheers for now- thanks for taking a look!
Old 02-13-2012, 02:13 AM
nostalgicrally's Avatar
nostalgicrally nostalgicrally is offline
Re: Trumpeter GT40
Very beautiful kit which we can modify to be even more complete. I admire the care, the cleanliness and the arrangement of your work plan.
Good assembly to you, I am you in your work
Eric
Old 02-13-2012, 10:53 AM
MerlinPro MerlinPro is offline
Re: Trumpeter GT40
A very excellent start to this build. I completed mine last year and agree about the problems you're addressing.
I'm not a scale machinist as you so my solutions are far more humble. I scratchbuilt much of the rear suspension to get a better look. I added details where visible. I did not solve the clamshell as you did so attached it shut. The oil hatch is open-able and detailed within.
If it's any help to you here's my WIP. Hope you find it useful: :
http://www.modelcarsmag.com/forums/i...p&fromsearch=1
I paid particular attention to the ride height, cockpit, engine bay and finish. I found great reference to be a huge help.
If I do another, I would shim the rear clip bottom edges with .010" stock to get a better shut line-your latches are great but I don't have that talent. A warning about pre-fitting: I found that when the cockpit tub was installed, and the roof section pressed over it, the mating line at the sill was difficult to get flush. I think another solution to the fit of the rear clip is to remove material from the inner upper edge where the clip rests on the roof tab-allowing the lower edges to seat more flush. General fit elsewhere on mine was good. Since completion, I've made small refinements such as replacing the clip hold down lanyards with .006" wire and small paint touch ups.
Look forward to your progress and solutions-I just may do another 'better' one...
Merlin
Old 02-13-2012, 12:49 PM
ianc911 ianc911 is offline
Re: Trumpeter GT40
Interesting car and what looks to be an inspiring build. I'll be following this one,
ianc
Old 02-13-2012, 03:50 PM
sebasoakley's Avatar
sebasoakley sebasoakley is offline
Re: Trumpeter GT40
Excelent built program..
Old 02-13-2012, 05:18 PM
puffyrs's Avatar
puffyrs puffyrs is offline
Re: Trumpeter GT40
I will be watching.
Nice work shop.
Old 02-13-2012, 06:46 PM
Re: Trumpeter GT40
Thanks to all for your replies. Sorry about the pics! I now know what to do to correct the issue.
Merlin, I've read and used your article frequently as a point of ref. so, many thanks for pointing out these other potential hazards. I did a lot of research so far including previous builds, like yours, by other modelers and forums for the real GT40's. I've had the pleasure of seeing and hearing a few of these beautiful race cars up close including the one at the Indianapolis Motor Speedway Museum. I'm glad Trumpeter made the investment to bring this kit to us in 1/12 scale.
I'll try to have more posted this weekend. Again, thanks everyone for taking the time to send your kind words.
John
Old 02-14-2012, 08:56 AM
Maysula Maysula is offline
Re: Trumpeter GT40
This will be intresting ! I did the #5 LeMans car last year, but will do another version later. Wich version are you going to do ?
Thomas
Old 02-14-2012, 11:13 AM
nugundam93 nugundam93 is offline
Blarg! Wort Wort Wort!
Re: Trumpeter GT40
nice build so far!
and those tools and paints all laid out neatly...wow.
olly olly oxen free
Old 02-15-2012, 06:11 PM
Re: Trumpeter GT40
Thanks Guys. I'm going with the kit version, at least, for now. I like the #5 and #1 option decals available but there's something about the black with those gold toned rims that really appeals to me. This may change........
Old 02-15-2012, 06:37 PM
Re: Trumpeter GT40
Be advised that if you're striving for accuracy, those other numbered chassis have some differences to what you get from Trump. Fuel pumps and cockpit details are examples. Get good reference for the exact car you're modeling and scratchbuild what's different.
Yes, 1046 looks great in black but the restoration changed a few things from the '66 LeMans configuration-like the roll cage came after, at Daytona.
Merlin
Old 02-17-2012, 09:01 AM
Re: Trumpeter GT40
Sonoma,
Thinking back on my build, another area for caution is the fit of the rear clip after the inner arch panel is bonded to it. It will either spread or pull the clip in tighter, changing it's shape.
If you haven't gotten to that point yet-trial fit the clip in place after the arch is white-glued and firmly clamped together.
Then check to see if your clamps still give a tight shut line.
Good luck.
Merlin
Old 02-17-2012, 11:10 PM
Re: Trumpeter GT40
Originally Posted by MerlinPro View Post
Sonoma,
Good luck.
Thanks again, Merlin. Actually, the inner arch is fitted in the photos posted. I spent some time beefy up the outer edges with styrene after I rounded the rear clip with the hair dryer.
Old 02-18-2012, 07:19 AM
John18d John18d is offline
Re: Trumpeter GT40
Yeah! I'm in on watching this build - I have one in the stash - John
Old 02-18-2012, 08:54 AM
Eric Cole's Avatar
Eric Cole Eric Cole is offline
Re: Trumpeter GT40
This is on my list to build this year also. I like how yours is coming together. I love the body latches, great job.
Eric Cole
Other Model Pictures Here:
http://s5.photobucket.com/albums/y197/justdande/
Trumpeter Ford GT40 Chassis Corrections David Layton Car Modeling 1 04-11-2011 07:56 AM
1/12 Trumpeter Ford GT40 replacement decals..? Rickard_Olsson Car Modeling 17 04-12-2010 04:20 PM
Trumpeter GT40 mikemechanic Car Modeling 36 02-28-2009 08:33 AM
** Roman Trumpet Sound PLEASE... ** sparq '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 17 03-21-2002 01:24 AM
Hella 3 trumpet horn Stormy Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 24 01-14-2002 09:28 AM
