Old 02-12-2012, 01:26 PM
woodie142 woodie142 is offline
Chevy S-10 code P0449
My truck needs either a new vent valve or Solenoid valve. How can I determine which one is causing the problem. I was told that the Solenoid is in the engine compartment and the vent is by the gas tank. Can you also tell me where the solenoid valve is located.
Old 02-15-2012, 05:16 PM
old_master's Avatar
Advisor/Moderator
Re: Chevy S-10 code P0449
What year is the vehicle, and what engine is in the vehicle?
You have to know how it works,
to figure out why it doesn't.
Old 02-15-2012, 05:40 PM
When I posted, I knew I forgot several things. The year is 2003 and the engine is a 4.3L V6 (VORTEC 4300 V6). The truck also has the extended cab.
Old 02-15-2012, 09:59 PM
old_master's Avatar
Advisor/Moderator
If P0449 is the only DTC you're getting, it's indicating a problem with the EVAP vent valve or its circuits. With a bi-directional scan tool you can command the valve ON and check for voltage and ground at the solenoid connector. If you don't have access to a bi-directional scan tool, it would be cheaper to just replace the valve, (fairly common problem) rather than take it to a shop for diagnosis and confirmation of a faulty valve. http://shop.advanceautoparts.com/web...RPEMISAMS_____ The valve is located near the fuel tank and EVAP canister. After replacing it, clear the OBDII memory and perform a drive cycle http://www.obdii.com/drivecycle.html If the SES light comes back on, your best bet is to have a shop diagnose the problem.
Post your results.
The Following User Says Thank You to old_master For This Useful Post:
woodie142 (02-16-2012)
1995 Chevy S-10 LowRider APAutoRepair Cars/Parts for Sale/Exchange 0 10-10-2011 08:31 PM
code p0449 evaporative emission canister misfit87 Uplander 2 02-23-2011 03:44 PM
Looking For early 70's Chevy K 10 Chevy.Crazy Car Buying Q&A 1 09-14-2010 12:56 AM
1990 chevy s-10 help! jgentil1 Interior | Exterior | Appearance 0 08-25-2009 07:30 PM
98 chevy s-10 blazer 4.3L v6 Vin code W teamster174 Problem Diagnosis 3 04-24-2007 09:24 AM
