Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 02-12-2012, 01:34 AM
nxm10 nxm10 is offline
2001 dodge ram 1500 slight Misfire Shudder/Stumble at idle in park or stop light/stop sign Please Help!!!
I just bought a 2001 dodge ram 1500 5.9 with 170,000 miles and it had a slight misfire shudder/stumble at idle so i replaced the plugs and wires but the problem didn't go away. I driving around town today and i got a p308 trouble code (misfire detected on cylinder #8) no other codes present. The misfire is only at idle theres no other problems at all while driving. Other then the slight misfire shudder/stumble at idle in park or a stop light or stop sign the truck runs great. Would a bad intake plenum gasket cause this? Any ideas/advice would be appreaciated.
Thanks
UPDATE: I checked compression on three cylinders and on #8 which is where the computer detected the misfire theres only between 55 and 60 pounds and on cylinder #'s 2 and 4 there was 125 pounds so im thinking a bad or improperly seated or stuck intake or exhaust valve on #8 causing the compression loss. I also looked down the intake with a flashlight and its clean and dry as can be.
And just an fyi i just bought the truck about three days ago and it sat for at least 9 months to a year before i got it.
Old 02-12-2012, 12:37 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 2001 dodge ram 1500 slight Misfire Shudder/Stumble at idle in park or stop light/stop sign Please Help!!!
I check for cracked vacuum hoses, loose intake manifold and throttle body bolts when I get that....easy stuff first.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 02-12-2012, 05:44 PM
jamesslcx jamesslcx is offline
nxm 10 check for vacuum leaks first. What kind of plugs were and are in your engine? How new is the distributor cap? Yes check the basics first. Sometimes the dodge engines don't like precious metal plugs.
Old 02-12-2012, 06:16 PM
Checked and all vacuun hoses good, intake and tb is nice and tight.
Old 02-12-2012, 06:21 PM
I installed autolite copper core plugs the dealer said thats what came stock in the truck. Not sure about the distributor cap but i checked the spark with a spark plug tester and it has good spark is good at the plug.
Old 02-12-2012, 06:53 PM
AF - Advisor
Sounds like a little rust on #8 valves & seats.
I'd take an hour, speed limit drive on a freeway/interstate somewhere and see if that cleans them up.
Maybe some 89 octane for the extra detergents.
Old 02-12-2012, 07:32 PM
nxm, yes possibly a sticking valve, try running some fuel system cleaner through it when you can.
Old 02-12-2012, 07:36 PM
I did not see your edit, hopefully not a burnt valve or worse, try the fuel system cleaner and run it kind of hard and see if that helps. Also run a detergent in the oil and change it if you haven't already.
'05 Dodge Ram 1500 - Tail Lights Not Working DodgeRam1500 Ram Pickup | Ram SRT10 10 12-27-2014 12:58 AM
NEED HELP!!! Dodge Ram Slipping Transmission jon2dope1987 Ram Pickup | Ram SRT10 2 09-04-2009 01:58 AM
2001 Dodge Ram 1500 5.9 Issues help!!! 2001dodgeram5.9 Ram Pickup | Ram SRT10 9 11-11-2008 11:36 AM
4x4 Light Stays On - 2001 Dodge Ram 1500 thebrownj Ram Pickup | Ram SRT10 3 11-07-2008 03:28 AM
FOR SALE 2001 Dodge Ram 1500 au23txchi Ram Pickup | Ram SRT10 0 07-17-2002 04:58 AM
