Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 11-11-2008, 12:39 AM
2001dodgeram5.9 2001dodgeram5.9 is offline
2001 Dodge Ram 1500 5.9 Issues help!!!
Hi I need help I have a 2001 ram 1500 with the engine light on. Anyone out there have a 2001 dodge ram 1500 with the 5.9 been able to successfully retrieve the codes stored without taking it in? I have a scanner that came up linking error whenever trying to scan it so I bought a better one (autoxray 6000) now waiting almost 2 weeks for it and it tells me "vehicle is not responding" on this one. This is after I called the company to confirm it WOULD work with my truck before purchasing it. Please help the check gauges light is on and the gas gauge stopped working (I put 10 galons in thinking it was siphoned) but nope still nothing. I can only start it by holding down the throttle and then as soon as I let off it dies instantly no trying to run or nothing, also if I hold the throttle in any position the rpms will drop off every half to one second then come back up. And finally when I just have the key in the ON position I can hear the sound of relays clicking over and over but dont know why. I am told that means they are working but thats it I dont know why they are clicking. I drove it yesterday about 100 mile round trip with no issues now today this, it only has 67k on it. Please any suggestions and anyone who has successfully retreived code please let me know and would be greatly appreciated Thank You so much
Old 11-11-2008, 12:42 AM
Re: 2001 Dodge Ram 1500 5.9 Issues help!!!
Sorry didnt think my First post went through my computer bugged out.
Old 11-11-2008, 12:48 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Make sure you don't have any blown fuses. There are some you may think don't have anything to do with the ALDL but they do!
Old 11-11-2008, 01:17 AM
Yes I did forget about them, went out and checked and there all fine, I wonder if part of this problem is also causing my scanner to not work properly as well.
Old 11-11-2008, 03:42 AM
angus10 angus10 is offline
Usually if it won't run without holding your foot on the gas, the IAC is bad.
98 Ram 1500 4x4
Flowmaster American Thunder W/super40
Old 11-11-2008, 03:45 AM
Hey awesome do you know how I can test it to be sure if it is working or not?
Old 11-11-2008, 05:31 AM
Without a realy good scan tool there is no real way of testing it. The best thing to do is remove it and clean it,and the hole where it goes into the TB and try it. If it acts the same or is a little better, then it's probably no good. Or sometimes it solves the prob.
98 Ram 1500 4x4
Old 11-11-2008, 09:31 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Can you get your codes by turning the keyswitch On-Off-On-Off-On then see codes on the odometer?
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 11-11-2008, 11:34 AM
I dont know about the odometer thing but I will try it. I performed an actuator test by holding down the odo reset then turning on the truck and it gave me 2 codes for the instrument panel 999 and 111. 999 is the code telling me it as found an error and i assum 111 is the error but I cant find any info on that, but that also isnt for obd just for the instrument cluster.
Old 11-11-2008, 11:36 AM
i will also pull off that IAC motor on the back of the throttle body. Thank you for the help so far!!!!
