Old 02-11-2012, 03:43 PM
mac12957 mac12957 is offline
s10 problem what to do next
have 1997 chevy s10 pickup and had not wanted to start when engine was hot. wait 20 minutes and starts fine. always started fine cold. replaced plugs wires cap and rotor, no difference. 2 weeks later had no start situation. had nice blue spark on all cylinders. coil tested weak so I replaced. tested ignition module was ok. fuel pressure tested 53 psi(key on not running) but pressure slowly dropped off. changed fuel pressure regulator cleaned top of intake under plennum replaced upper intake gaskets and now truck starts nice. however after started idles rough and stumbles when leaving stop light. has all kinds of power while driving down road. I get code p0141 (oxygen sensor bank1 sensor3). wiring checks ok so I replace sensor, code goes off and stays off. I drive truck and after 15 miles loses power and acts like cat. converter or muffler is plugged. I get home and replace cat converter and muffler (has not done this again). still runs roughand stumbles when taking off from stop. I clean maf sensor, clean iat sensor,and clean egr valve,no change in performance. next I use multimeter and check tps, map sensor, and iag valve. all check out ok. I now am also getting p0171 and p0174. I check fuel pressure again and is still at 53 psi(not running) and droppes to48 psi at idle.I am still getting a drop in fuel pressure when tested. Is pump bad or spider injector bad or something else bad? running out of ideas! please help!
Old 02-11-2012, 06:44 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: s10 problem what to do next
Fuel pump????
Pump needs 60/66 lbs pressure.
4.3 v6 CSI
64 engine cranking.
56/62 SFI 4.3.
59-60 engine cranking.
MT
Old 02-11-2012, 09:46 PM
old_master's Avatar
Advisor/Moderator
Low fuel pressure and excessive leakdown is your problem. Most likely a weak fuel pump and leaky check valve in the pump. Key ON, engine OFF, fuel pump running, fuel pressure must be, (as MT stated) 60psi to 66psi and must remain above 55psi for 10 minutes after the pump shuts off. Stay away from aftermarket fuel pumps, use AC Delco or Delphi only.
You have to know how it works,
to figure out why it doesn't.
94-S10 - Dies while driving and other misc. wacky problems avlind S-10 4 09-30-2010 05:18 PM
2003 s10 transmission problems burk4200 Problem Diagnosis 6 03-30-2009 07:07 PM
Stumble problem, also what next? boostjunkie333 Engine, Transmission and Drivetrain 0 07-17-2008 05:03 PM
What next for my suspension? hondacsi Tires and Wheels 10 01-22-2002 05:08 PM
Bought my first G20 today!!!....what next?? northwestrally General 7 05-03-2001 12:31 AM
