Old 02-11-2012, 01:19 PM
mdallison mdallison is offline
repair or replace gas pedal
I have a '89 Buick LeSabre custom...the problem is the gas pedal has dropped to
the floor and does not seem to connect to the throttle body. I can move the pedal
up and down by hand--but there is no action on the throttle at all. I assume there
must be a spring or connection somewhere that has come loose.
this is my only form on transportation...Help Please
Thanks for Your help
MD Allison
Old 02-11-2012, 01:34 PM
DeltaP DeltaP is offline
Re: repair or replace gas pedal
Possibly the cable broke although unlikely. But with that age I wouldn't rule it out. Most likely a linkage clip came off at the throttle body. (under the air cleaner).
The Following User Says Thank You to DeltaP For This Useful Post:
mdallison (02-11-2012)
Old 02-11-2012, 07:44 PM
Tech II Tech II is offline
I agree..cable broke, or came off the pedal or the throttle plate linkage....
The Following User Says Thank You to Tech II For This Useful Post:
Old 02-11-2012, 09:02 PM
Hey Thanks so much Y'all...
yea, i do believe it is the broken cable thing--
i tried to remove the gas pedal; but haven't
had any luck.
I think i have something to tell the mechanic
at any rate, so I can get some idea of cost.
Again...
Thanks so much
many blessings
MD
Gas pedal went to the floor on its own! bagem788 Traverse 8 11-08-2017 06:08 PM
Gas hard to push when accelerating...why? jesswinz 323/Protegé/Familia/Etude/Allegro 0 02-21-2010 04:46 PM
2000 Sonoma Gas Pedal on floor but no acceleration timaugie Sonoma | S-15 0 07-29-2009 02:25 AM
gas pedal sticking and brake pedal making weird noise? 00'GMCYukon Yukon 3 05-11-2005 08:40 PM
