Old 02-10-2012, 04:49 PM
RDCragg RDCragg is offline
Suspension Noise
My 2000 Windstar is making a popping noise when a load is added or removed from the front suspension. The sound is coming from the driver's front side. The steering wheel is now centered at the 1 or 2 o'clock position. I have parked it so nothing more serious happens.
Any suggestions on what to look for before I take it into the shop? Thanks.
Old 02-10-2012, 06:44 PM
tempfixit tempfixit is offline
Re: Suspension Noise
You might want to jack the front wheels of the ground thenplace your hands at the 9 and 3 oclock possition theen see if there is any movement, if so check the tie rod ends both inner and outer.
Also place your hands at the 12 and 6 oclock positon and see if you have any movement in the lower ball joint.
Have you bounced the front end while by hand to see if you ccan dupliicate the popping??
Also check the sway bar end links and struts for looseness.
Old 02-12-2012, 06:17 PM
wiswind wiswind is offline
The BEST advice I can think of is to have it checked out by a good mechanic.
It could well be something very minor......or serious.
Suspension noises travel and can drive one crazy.....and there are a number of minor things that can cause a lot of noise.
However, until someone who knows what they are doing checks it out, you won't know.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 02-12-2012, 06:52 PM
82Stang 82Stang is offline
If the steering wheel is moved, then something shifted. If you are atleast handy, you can jack up the left front, jack from the body, not the lower member, and check from left to right for tie rod looseness. And top to bottom for ball joint looseness. But to me, the 'popping' suggests a faulty axle shaft(CV joint). That is the only moving part in there, aside from the wheel bearing hub assembly, which also would have movement from top to bottom AND left to right if bad. In some cases, the bearing just moans with engine rev/rotation and doesn't necessarily feel loose. An outside chance it could relate to the strut/assembly, but I'd want to be sure before ante-ing up for that.
Temp has the right idea. But so does Wiswind, if you don't have a nose or know how for mechanics, you might want to find someone who does. Having a wheel pass you, is no fun.
"When I was a kid my parents moved a lot, but I always found them."
Rodney Dangerfield
2000 venture suspension noises/woes pjw73nh Venture 27 02-28-2010 08:01 PM
Creaking Noise At Front-End el ratfink Pacifica 2 12-05-2009 11:57 AM
97 Cavalier 2.2L suspension noise 72GMC Cavalier 3 11-26-2003 05:32 PM
annoying suspension noise eriojas C/K 3 10-28-2003 04:48 PM
2000 Accord Coupe Suspension noise rsia23 Accord/TSX/Accord Hybrid 2 10-29-2002 01:53 AM
