Old 02-10-2012, 12:36 AM
papason papason is offline
C clamp with bolt drive instead of T handle for tightening.
I broke a stud on my exhaust flange -one of 3- so for now or forever, was looking to clamp that spot and only thought of C-clamp so far.
Not a lot of space for two hands and need to get some torque on it too. Seems like I Have seen clamps with a nut for tightening them but cant find one.
so hoped somebody here either knows one or a good substitute.
Old 02-10-2012, 09:43 AM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Re: C clamp with bolt drive instead of T handle for tightening.
If you already have a clamp of the approximate needed , simply cut off the sliding T - handle used to tighten the clamp . Get a hex nut of the appropriate size and weld it onto the clamp shaft head .
" Sometimes I grow so tired "
Old 02-10-2012, 12:04 PM
Thought of that. That doesn't look like weld able material, but I have. O welding tools
Old 02-10-2012, 03:57 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Originally Posted by oldblu65 View Post
If you already have a clamp of the approximate needed , simply cut off the sliding T - handle .
As mentioned, cut off the handle and grind the end of the shaft into a square. You can then use a 8 point socket on the square end to tighten. Size the square approx 3/8" or 1/2" or whatever is appropriate so you can use a standard size socket.
And BTW, I have seen c-clamps for this type of repair over the years..
I love backyard engineering..
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 02-10-2012, 05:03 PM
DeltaP DeltaP is offline
Both ideas are good and that'd be a good fix somewhere in the third world but come on guys this is America. You'll go through as much effort as fixin it correctly!
Old 02-11-2012, 03:26 AM
I like that idea on many levels. I will give the grinding a try.
For now this is the right way, as it is probably better to clamp than not. removing the the broken stud ect. cant happen for a while.
Seems lkike I have seen these clamps but cant find one or anybody who has seen one.
Traction Control light Cancel comes on, Clamp Alignment azakram CTS and CTS-V 0 09-11-2010 02:11 PM
Need spare tire clamp/jack bolt??? DanMan7 Metro 3 02-08-2007 11:53 AM
Tata Motors drives home with Nissan`s SA plant for Rs 210 mn - Myiris.com Automotive News Automotive News Desk 0 08-18-2006 04:50 AM
I need a bolt..........Help....Will work for Bolt E Honda '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 09-24-2005 03:34 AM
Going with a C4, instead of Tremec SkylineUSA Mustang Talk 6 06-27-2005 01:44 AM
