Old 02-09-2012, 05:49 PM
spowel4 spowel4 is offline
1989 LeSabre error code 48
My '89 LeSabre has begun idling high when in Park, but as soon as I put it in gear (Drive or Reverse, doesn't matter), the idle drops down. The error code is a 48, which I can't find in the code charts. Anyone else had this happen & can point me in the right direction? BTW, it's also been giving a code 63 for a while now, which has to do with the cruise control. Since the cruise doesn't work on this car anyway, I've ignored the error, but if it's something that's a quick fix I'd appreciate any advice on that one too.
Old 02-09-2012, 09:07 PM
Tech II Tech II is offline
Re: 1989 LeSabre error code 48
I can't find a code 48 either.....sure you have the right code?
63 shows up as an EGR problem.....
Old 02-09-2012, 11:00 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Code 48
4 flashes, pause 8 flashes
Misfire Diagnosis. Check the ignition and fuel systems.
The older model ECM cannot detect individual misfires, only the units responsible for firing. You could have a problem with the cam sensor, crank sensor, ICM, coils, or associated wiring.
'97 LeSabre error codes jcc3inc LeSabre 2 09-05-2009 03:40 PM
95 Buick Lesabre error codes ChuckSnyder LeSabre 0 06-12-2007 07:18 PM
96 LeSabre error code p411m LeSabre 5 01-18-2007 07:34 AM
