Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 02-07-2012, 11:27 PM
Rizin84 Rizin84 is offline
1992 Explorer 4.0
Well i have a 1992 for explorer 4.0 all lights seem to dim kinda surging at idle or coming to a stop. Has new battery, battery cables nice and tight new alternator. my Volt gauge on my cluster jumps from 12 to 14 volts. battery light flashes seems to be getting worse. Was having similar issue about 1 year ago found a injector giving up. Replaced injector and worked good for a while Wondering is it common to have that issue with injetors causing these issues. Doesnt seem likes its missing firing
Old 02-08-2012, 07:44 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 1992 Explorer 4.0
Based on the description provided, it sounds to me like you have a vacuum leak. Since you mention the charging system though, is there a reason you think it may be charging system related? How low is the engine speed dropping at idle? When you mention "dim kinda surging" are you saying the surging is subtle, or the lights dim?
-Rod
1992 explorer with4.0 heartj Explorer | Explorer Sport Trac 3 10-11-2005 11:03 PM
1998 explorer 4.0 ( spark knock?) ntmud8r Explorer | Explorer Sport Trac 2 03-03-2004 12:19 AM
99 Explorer 4.0 4R44 Trans Help ReVenge Explorer | Explorer Sport Trac 1 02-24-2004 09:13 PM
Explorer 4.0 ohc block/pan ladder girdle? cossie builder Explorer | Explorer Sport Trac 0 11-12-2003 03:36 PM
1996 ford explorer 4.0 rtd2 Explorer | Explorer Sport Trac 0 06-04-2003 11:08 PM
