Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-07-2012, 10:14 PM   #1
Abella
cylendar 1 and 6 misfire
i got a 2002 3.8 essex the code comes up as p0316 misfire cylendar 6 first 1000 rpms and p0301cylendar 1 misfire i changed the plugs to bosch platnum when i got it a few months ago less then 3k miles on them. just put new autolite wires on it two days ago with dielectric grease. pulled cylendar 1 plug and its clean no carbon no oil dry and clean. no smoke coming from the exaust and no sweet smell so i dont think im burning coolant or oil. no mechanical damage on the plugs. when i unplug the wire from the coil pack it gets worse so i dont think its the coils. it hessitates when i give it gas but thats because of the misfire. i sprayed the vaccum hoses that i could get to with starting fluid with it running and it didnt rev up so i dont believe there is a vaccum leak i need to check compression but other then that i cant think of what it would be. im about to go check the gap on the plugs but i know the wires on the cylendars are right. it also sometimes dies on occassion and throws a code but when i start the car again it goes away idk if they are related problems but that would be my guess i just hope its not a burned valve or sticking lifter. i really dont want to have to get into the block
Abella is offline   Reply With Quote
Old 02-07-2012, 10:23 PM   #2
wolclan429
wolclan429's Avatar
Re: cylendar 1 and 6 misfire
its sounds like you need that compression check, and you are on the right track check all you did and it may led to the internals etc,
wolclan429 is offline   Reply With Quote
Old 02-07-2012, 10:58 PM   #3
tempfixit
Was the problem existing when you installled bosch plugs??? Many engines do not like bosch plugs. What brand plugs were init originally???
tempfixit is offline   Reply With Quote
Old 02-07-2012, 11:25 PM   #4
Abella
autolite plugs aka ford plugs everything on this car is original until i got it at 146k miles
ive never had a problem with bosch but i just broke on taking it out a min ago so ill have to get a new one tomorrow for cylendar 1
Old 02-07-2012, 11:27 PM   #5
Abella
and honestly i dont know about existing problems it had a check engine light when i got it and they told me that they took it to a mechanic and they said it needed new plugs and i took it to autozone and read the code that said cylendar 1 misfire and cylendar 1 misfire on start up so i changed the plugs and it when away until just the other day.
Old 02-07-2012, 11:51 PM   #6
Abella
i mean i pulled the end of the wire from the coil and it got worse but idk if that neccicarly means the coil pack is good. it could still be a weak connection i guess
Old 02-08-2012, 12:17 AM   #7
tempfixit
I would try the autolite plug since you have to replace anyway.
Old 02-08-2012, 12:22 AM   #8
Abella
yeah im going to have to make a mad dash to the part store tommorow morning using that cracked plug idk i really just dont want it to be internal i can deal with small things but i dont have the time to fix internal issues and i dont have the money to take it to the dealer.
Old 02-08-2012, 03:00 AM   #9
tempfixit
If you have not already done so I would also add some fuel injector cleaner to your fuel.
Old 02-08-2012, 11:21 PM   #10
Abella
ive ran both lucas oil tune up in a bottle and also seafoam through it. i do not think it is the injectors i pulled the broken plug this morning and replaced it with motor craft and i plan to do all the other ones once i get this fixed i cant even begin to mention how shitty bosch plugs are compared to motor craft. anyways i replaced the plug and it got much smoother and it also got smoother with the new wires my next step would probably be coils. i honestly dont think its an internal issue because there is no smoke and every car ive every worked on if there is an internal issue that is due to a bad seal or bad gasket there is always a shit ton of white or blueish smoke. it could a burned exaust valve but i dont think it is that either my exaust smells richer but nothing compared to what it could be. also it is firing it says misfire but there is still firing because i drove it with a broken plug just down to the parts store this morning and it was alot worse so im thinking it might be ignition
Old 02-12-2012, 01:23 AM   #11
Abella
so after replacing the plug with a motor craft i turned it on one morning and the check engine light went off so i think it fixed it the weird thing about my car is even with a mis fire you really cant feel it like ive had cars with misfires and you could tell but this one you really couldnt so idk if its fixed or not but ill prolly put a new ignition coil just to be and check the new plug for oil or coolant in a couple of days
Old 02-12-2012, 01:44 AM   #12
tempfixit
Thanks for posting and hopefully you have it fixed. Let us know if it acts up again.
Old 02-13-2012, 07:10 PM   #13
wolclan429
wolclan429's Avatar
[quote=Abella;6958560]i got a 2002 3.8 essex , If you have calylitic converters on one on that side could causing the problem sometimes as well, especially with it being an on and off thing, the computer sometimes read that even if the converter is bad
Old 02-13-2012, 09:31 PM   #14
Abella
yeah but i have not noticed a smell in my exaust like youd get from a malf cat idk im just going to drive it until the light comes back on im really jus holding out until this summer when im getting dual exaust put in in and maybe a v8 i got the parts its just too fu'king cold to do anything here in indiana
Old 02-13-2012, 09:47 PM   #15
wolclan429
wolclan429's Avatar
You could be right I have some under the hood front end painting I want to do but its in the 30's here now. just painted one off headers for my one off 429/460 05 and that was just a week ago now I would not paint anything even with the salamander heater on,
95 4wd rough start if start and misfire and sputtering like it is running 3 cylinders gmc95 Jimmy 2 05-28-2005 07:27 PM
problems starting and misfire stilly Grand Prix 1 11-27-2004 02:31 PM
1994 passat-overheating and misfiring Spackman '93 - '96 3 09-26-2004 12:47 PM
1996 ford ranger rough idle and misfire micvm Ranger | Courier 1 08-04-2004 09:45 AM
98 sierra 5.0, Hesitation and Misfiring Problems 98sierraman C/K 2 03-13-2004 09:53 PM
