Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 02-07-2012, 07:57 PM
papason papason is offline
broke a stud on exhaust flange 2 of 3 left do I need to do something about it. what is the torque for the bolst
94 pickup 22re. replaced the header pipe 2 nuts a bear to get off and broke one of the studs in trying. Put the new pipe on, looks good and tight, sounds good for now. Any one know if it will definately start leaking? or if so how soon. could I clamp it? with what?
What is the torque for the nuts on that?
Thanks
Old 02-12-2012, 01:49 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: broke a stud on exhaust flange 2 of 3 left do I need to do something about it. what is the torque for the bolst
It's bound to start leaking, hard to say when.
I couldn't find torque spec for the exhaust system, but a standard M10-1.25 bolt is 19 ft-lb and a M12 is 35 ft-lb.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 02-12-2012, 06:04 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Torque is 33 ft-lbs for head to manifold nuts.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 01-03-2014, 12:34 PM
Update.
It was not a good time to try and remove the broken stud I found a c clamp that fit up there and was able to torque it pretty tight and it is still there LOL. When the weather warms I plan to try and fix it right.
Everyone knows the 2.7 is junk do something about it JTspeed419 Intrepid 2 07-19-2009 10:49 PM
I said I'd do something about it... Christ '88 - '91 Civic | CRX | Wagon | Shuttlee 27 08-29-2008 08:01 PM
Global Warming - your chance to do something about it YogsVR4 COMPLETELY off-topic 32 09-02-2005 03:18 AM
noisy ride - should i do something about it? sixleggedinsect Escort 5 01-30-2005 03:25 PM
whats the torque setting for the mount bracket? hitr99 '88 - '91 Civic | CRX | Wagon | Shuttlee 1 02-19-2004 05:42 PM
