Old 02-05-2012, 01:13 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
No Start
1999 Chevy Blazer 4.3 4x4
I am having a problem where I turn the key and I have no power. No lights come on, no fuel pump priming, nothing. I had the negative cable off the battery and the PCM disconnected to remove the blower motor. Reconnected the cables to the PCM and the negative cable to the battery. I had faint lights and faint power to the windows locks etc but now nothing. Like I said when I turn the key, I have nothing at all. I retraced my steps to see if I forgot a connection at the PCM but nothing is missing. I retook the battery cable off and removed PCM again and reconnected everything.
Battery replaced Nov. 2010, alternator replaced Nov. 2010 but from searching I am seeing either a bad cable or bad connection at the battery as the problem. I also have no under hood light on. I checked fuses in both boxes and certain fuses you can hear noises in the dash when they are removed. I checked them with a fuse checker and they were good.
Going to try to find the meter/test light to see if I got voltage going across the cables.
Any suggestions?
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
Old 02-05-2012, 03:02 PM
Re: No Start
Can't get volt readings as the voltmeter is dead.
Going to run that battery over to Autozone tomorrow to see what it reads.
When I connect the cable, I do hear a noise in the engine bay like a relay or something to that effect is kicking on.
Old 02-05-2012, 09:32 PM
Re: No Start
Bad battery, checked at autozone, it failed and was replaced. Car starts/runs great again.
01 sierra nothing happens when key turned to start nostalgia gas Sierra 3 02-12-2012 05:35 PM
No start, start, no start, start+smoke CLR01 Blazer 14 02-26-2006 01:22 PM
Starts....doesn't start...starts kennycu Park Avenue 3 08-11-2005 10:05 AM
89 Bonneville - Starts, Doesn't Start, Starts, Doesn't Start joshshrag Bonneville 2 04-24-2005 01:24 PM
1989 Bonneville - Starts, Doesn't Start, Starts, Doesn't Start joshshrag General Discussion 0 04-19-2005 06:33 PM
