Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 02-04-2012, 04:37 PM
scorpionking scorpionking is offline
Transmition my be shot!
i will make this short...my engine blew (female driver with no oil)...so far a good junkyard engine was installed...the problem now is after we drove 40 miles, the car would not go into reverse...we stopped stopped driving…check dip stick...no transmission fluid at all...fluid all over the ground...did not drive once noticed...towed back to shop...he said possible burned gears...QUESTION, when installing a engine, is there any way to loose transmission fluid...these folks change engines all the time...i just want to gain some good knowledge on how to address issue...
Old 02-05-2012, 06:57 AM
FishFind FishFind is offline
One Hot Shot
Re: Transmition my be shot!
Yes, first you have the cooler lines that to to the radiator and that has to be taken out to get engine in. Also the torque convert clutch goes up into the engine and is sealed where the transmission and the engine meet.
Old 02-05-2012, 08:23 AM
but i thought where the tranny and engine meet did not hold transmission fluid...i thought the tranny fluid was actually in the tranny...for example, after removing the engine, you got the tranny still sitting there...if still sitting there, the tranny fluid was fine because of being internally in the transmission???
Old 02-05-2012, 08:28 AM
also failed to mention, it’s an automatic
Old 02-29-2012, 11:14 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Correct, the space where the torque converter is does not hold fluid. It is all contained within the TC. Fluid can leak out between the tranny and TC, from the pan, or from loose tranny cooler fittings to/from the radiator.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 03-01-2012, 01:06 AM
Joe W Joe W is offline
IMHO I believe there is no correlation between the engine replacement and the trans failure, especially as you note there was tranny fluid was all over the ground. If you can locate the source of this leak you can localize the failure.
94 explorer transmition xzyan Explorer | Explorer Sport Trac 3 07-05-2004 05:24 PM
What are the pros and cons of the manual and the automatic transmition? dapriceiswrongb Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 9 04-02-2003 08:59 PM
transmition QBA 323/Protegé/Familia/Etude/Allegro 0 02-13-2003 06:07 AM
Problems With Transmition??? Help! Indyg20 Engine 8 01-17-2002 11:31 AM
