Go Back   Automotive Forums Car Chat > Chevrolet > Express | G Van
Old 02-03-2012, 01:51 PM
papher51 papher51 is offline
brake problems
I have a 2006 1500 express van. New brakes about 8 mos. ago. At the end of each stop it feels like the brakes lose grip. It resembles a stop that the last few feet were on ice and it slide. Pedal stays up and is not spongy. When I replaced the brakes I got the ceramic pads and new rotors. Any ideas??
Old 02-03-2012, 02:35 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: brake problems
ABS kicking in at low speeds.
May be bad speed sensor but you need to get abs brake codes to pinpoint the problem.
Always CHECK FOR abs CODES BEFORE TURNING OFF IGN.
Post back code no.
MT
The Following User Says Thank You to MT-2500 For This Useful Post:
papher51 (02-03-2012)
Old 02-03-2012, 04:11 PM
Re: brake problems
Sensor was dirty, I cleaned and all was well. Thanks
Old 02-03-2012, 04:19 PM
MT-2500's Avatar
AF - Advisor
Re: brake problems
You are welcome and thanks for posting back how it went.
MT
2003 Toyota Camry LE 4-cylinder brake problem Paola Camry/Camry Hybrid/Vista 2 11-23-2011 11:12 PM
98 lumina brake problems, NEED HELP!! belowsubzero Lumina 5 07-15-2011 09:03 AM
89 ford bronco 2 brake problem bigd428 Bronco 0 09-13-2010 09:14 PM
brake problem, VERY hard brake pedal but VERY little braking power 95GMCJimmySLE Problem Diagnosis 23 10-24-2009 02:41 PM
Braking Problems frehleycomet Tracker 2 03-29-2009 10:46 AM
