Old 01-30-2012, 08:02 PM
spugeddy spugeddy is offline
Add changing blend door acuator to repotrois
Sorry I guessed at the spelling, didn't take French.
Heat went out and clicking sound behind the radio was going on as you tried to adjust from cold setting to heat on the slider....
Bought part at Advance Auto (may regret that if it fails) Got to it by removing radio, and bottom trim surround (one that has the CD/storage bin that angles out) below the cup holders. It is definatley a "lady hands" special. Plus I hope you like working on your back and not being able to see well. Anyway, took about 1hr 15 minutes taking my time. Tested before buttoned everything up.
The only critical step is making sure the position of the "stem" (has a D shape tip) is in the same orientation as the one you are taking off. What I did was hooked up the new one and turned the key on, then adjusted the slider control until the position of the new stem "d" matched the same orientation as the one I was taking off.
It was 8MM hex head screws/bolts, and I did buy the stereo removal tool.
Can't wait to sell this thing.... I am on borrowed time.
Location Blend Door 95 accord? spayordie Accord/TSX/Accord Hybrid 2 06-21-2012 01:49 PM
Blend Door Actuator or Plugged Heater Core? CryptoJones Windstar 10 01-23-2011 10:33 PM
2003 Sable blend door actuator not working rdhaley Sable 1 03-02-2010 09:00 PM
97 Caravan AC Door Acuator berger316 Caravan | Voyager 1 10-18-2008 02:16 PM
Wiring 5 Wire Door Acuators to RELAYS MikesBomb420 Tercel 1 11-26-2003 06:16 PM
