Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 01-29-2012, 03:06 PM
jedge jedge is offline
2002 Suburban stalls and sputters after driving thru water.
After driving through high water (only 12"-18" deep), my 2002 Suburban stalled. It restarted but runs rough, doesn't idle well, and still stalls and sputters under acceleration. A week later (it's been dry and I've driven it 70 or so miles since the water), it's still stalling and sputtering. Under braking, I must keep the accelerator down enough to keep the RPMs slightly above 1000 or it will stall. Obviously something got wet that shouldn't have gotten wet.
Old 02-07-2012, 07:43 AM
j cAT j cAT is offline
Re: 2002 Suburban stalls and sputters after driving thru water.
the computer/pcm is in a bad spot. remove the cover and inspect the connectors/pins for corrosion.
also the air box can trap water. I have put 1/8 in drain holes in it so water can drain out. check that air filter is dry/must be dry.
Oil Leak after Drive Thru Oil change Bill-SILV F Series 8 12-23-2009 06:54 AM
93 Scoupe pings, stalls, and sputters...anybody recognize? dmertz S Coupe 1 11-09-2008 08:01 PM
2.8 88 s10 stalls and sputters at idle without brake depressed and dosen't w/brake supercoupe22 S-10 3 11-29-2005 04:16 PM
91 V6 Cav stalling and sputtering probs kylekyle Cavalier Problem Diagnosis 1 10-26-2005 12:41 PM
1993 Cutlass stalling and sputtering Disco Dave Cutlass Series 8 08-30-2005 11:04 PM
Tags
2002 , stall , suburban , water
