Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 01-29-2012, 12:33 PM
00rodeodave 00rodeodave is offline
cooling issues
I have a 2000 rodeo that I just put a new timing belt and water pump and thermostat. It does not over heat but it is blowing coolant out ove the overflow and the pressure on the hoses seems really high. I was looking to see if anyone has had this problem and what I can do?
Dave
2000 rodeo ls ,3 ind. off road lift, 31" geo-landers
rancho 9000/s
72' 1200 hd custom (money pit!)
03' suzuki aerio sx
07' suzuki sx4 awd ( best bang for the buck )
Old 01-29-2012, 01:21 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: cooling issues
Change your radiator cap ...
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 01-29-2012, 02:04 PM
Cat Fuzz Cat Fuzz is offline
Re: cooling issues
You need to get the air out. Remove the radiator cap and squeeze the hoses until the air bubbles stop. Sometimes rocking the car side to side will help dislodge air bubbles.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Old 01-29-2012, 08:15 PM
Re: cooling issues
Its has a new radiator cap and I did the steps on removing the air form the system. After I get the air out its fine for about 3 days. Then it starts burping into the overflow. After that it just gets worse. But I get hot air from the heater all the time with out any cold shots. The thing just builds pressure for some reason. No oil in the fluid or fluid in the oil. No leaks anywhere. And it runs normal temp.?
Dave
rancho 9000/s
03' suzuki aerio sx
Old 02-01-2012, 07:17 PM
Re: cooling issues
Well Thanks for the tips all. I found out the problem it was and is a head gasket. Lovely?
It tested positive for hydrocarbons in the coolant.
Dave
rancho 9000/s
03' suzuki aerio sx
Cooling issue, new to troopers, please help! 93troop Trooper | SLX | Bighorn | Wizard 3 09-07-2004 08:12 PM
94 Civic DX cooling issues. Panda_Integra '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 08-09-2004 01:38 AM
95 camaro cooling issues... vlaar Camaro Discussions 5 02-15-2004 02:47 PM
Coolant/Cooling Issue - Please Help chrizg Blazer 1 12-18-2003 06:39 AM
