Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 01-29-2012, 10:09 AM
andreval andreval is offline
2008 Sierra Traction Control´/ ABS Light
I have a sierra 2008 Crew Cab ,5.3l , Z71. Yesterday I was driving in snow (wet snow and slush ) both light came on ( Traction Control and ABS )
Any suggestion what the problem might be.
Thanks Andy
Old 01-29-2012, 07:22 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 2008 Sierra Traction Control´/ ABS Light
Need to see what codes(s) are stored. You could do a visual inspection of the speed sensor harnesses and check for damage.
The Following User Says Thank You to gmtech1 For This Useful Post:
andreval (01-30-2012)
Old 01-30-2012, 06:33 AM
On my OBDII it reads : No DTCs codes presently stored in the vehicle ECU.
Thanks Andy
No Codes on OBDII
Old 01-30-2012, 10:50 AM
gmtech1's Avatar
Are you sure the scanner you are using is able to read ABS codes? Alot of code readers cannot read ABS codes. If the ABS and TRAC lights came on, there should be a code stored.
Old 01-30-2012, 11:17 AM
I am using a scanner made by TOPTAK Model OT-680.
Andy
Old 01-30-2012, 12:21 PM
gmtech1's Avatar
I think that scanner will only read emissions related codes. Unless there is a menu on it specifically for ABS, you'll need to have a shop with the correct scanner check for ABS codes.
Old 01-31-2012, 08:14 AM
GMCustomerService's Avatar
GMCustomerService GMCustomerService is offline
Looking forward to an update on this, Andy! If I can be of any assistance in working with a dealership, please send me a private message with some more information and I'm happy to help (include your name, the last 8 of your VIN, and the name of your dealership, please).
Regards,
Sarah
GM Customer Service
The Following User Says Thank You to GMCustomerService For This Useful Post:
andreval (01-31-2012)
Old 01-31-2012, 08:40 AM
Hi Sarah, let me know if you received my private message.
Andy
E-Mail: [email protected]
ABS Traction control Module (HELP) ohio45344 Park Avenue 3 01-03-2011 09:53 AM
ABS and Traction Control Lights on after Jump start jbinramona Seville 0 06-22-2010 10:11 AM
00 venture traction control abs light always on scattmann Venture 3 06-05-2007 02:41 PM
Traction control/abs light come on gherikill Impala | Impala SS 5 01-05-2007 01:18 PM
96 olds achieva traction control abs light on Bruconator Achieva 1 02-19-2005 12:48 AM
