Go Back   Automotive Forums Car Chat > Daewoo > Lanos | Kalos
Old 01-26-2012, 12:40 PM
coolmoe coolmoe is offline
Turn signals are out.
On my daewoo lanos 2001. I need to get a state inspection and cant pass with out them. It does not click or any thing when I use the turn signals, the hazard lights do not work as well. I was told its probably my turn signal relay but I cant seem to find it. I know it should be in the fuse box under the hood. But I do not know witch one it is. I took it to auto zone and showed them the fuse box and they could not figger out witch one it is. So hear is a picture of the fuse box map. Do you know witch one it is? Or maybe its not in the fuse box under the hood?
http://i801.photobucket.com/albums/y...0126121231.jpg
Is the problem my turn signal relay fuse? Or could it be something else?
Old 02-20-2012, 08:36 PM
Lanos Driver Lanos Driver is offline
Re: Turn signals are out.
If the relay is not in the fuse box under the hood, check behind the small door in the kick panel just forward of the driver's door. I'm not saying you will find it there, but a place to look.
Good luck.
Old 11-07-2014, 01:41 AM
LeoTheLion89 LeoTheLion89 is offline
Send a message via ICQ to LeoTheLion89 Send a message via AIM to LeoTheLion89 Send a message via MSN to LeoTheLion89 Send a message via Yahoo to LeoTheLion89 Send a message via Skype™ to LeoTheLion89
The Daewoo Lanos does have a turn signal relay. It is a big square shape relay black in colour its got 3 prongs and i SHOULD be under the dash closest to the driver side door there is plenty of relays in that area so it may or may not be easy to spot. My Daewoo is the 1st car ive ever owned that HASNT had this problem.
04 Saturn Vue - turn signal keeps clicking even when there's no signal on richter343 Vue 4 07-19-2010 06:20 PM
Turn Signals are Winding Down jagchick Aurora 4 07-30-2005 12:00 PM
turn signals are blinking fast ReCKleZ Camaro Discussions 13 06-13-2005 02:08 PM
turn signals going out poppy 5 Series 0 01-11-2005 01:38 AM
ABS Light and Turn signal went out Can someone Help?? diesel1976 C/K 1 05-05-2004 11:28 PM
