Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 01-25-2012, 04:46 PM
bz2fx8 bz2fx8 is offline
Send a message via AIM to bz2fx8 Send a message via Yahoo to bz2fx8
96 Camry dash light Problem
This is a 96 camry with 309k miles. 4cyl 2.2l. the oil and the seatbelt light stay on after the car is turned off. I have changed the oil and it still lights up. I disconnected the battery over night so it won't drain it. I also had the battery tested and it was good. If I start the car the oil light goes off and then i put my seat belt on and the light goes off. if i turn the car off and i have my seatbel still only the oil light comes on, if i take the seat belt off and remain in the car the seatbelt light still stays on. ANy suggestion on what to try or a fix, please let me know!!!
I would also like to add, that i have tested the oil pressure switch as intructed by the manual and it seems to fine. unless someone suggest to replace it, i might!
Old 01-25-2012, 05:39 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 96 Camry dash light Problem
Check your alternator. A bad one can the source of some weird dashboard light behavior.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
The Following User Says Thank You to Brian R. For This Useful Post:
bz2fx8 (01-26-2012)
Old 01-25-2012, 06:28 PM
DeltaP DeltaP is offline
Usually a bad diode in the diode trio of the alternator will cause the "Alternator" light to glow dimly. It wouldnt surprise me if it was feeding back to any other ground circuits as well. You could try to disconnect the alternator B+ cable from the alternator and leave the battery connected to see if those lights remain on. That would confirm or eliminate the alternator. Make sure you tape up the B+ cable end when you disconnect it and don't let it touch anythng as it's a hot wire and can carry considerable amperage.
The Following User Says Thank You to DeltaP For This Useful Post:
bz2fx8 (01-26-2012)
Old 01-26-2012, 08:07 AM
Thank You!! for your reply. I checked the alternator connection (side electrical connector) oval shaped. it had the 3 wires fraid and they seems to be touching. i wrapped each of them with electrical tape and replugged it back. i had the battery cable disconnected when i did this,so when i reconnected the battery cable back the lights didn't return. i drover the car for about 30min and when i turned it off, the lights stayed off. Once again Thank You!, i would have never guessed it would be the alternator.
1985 Riviera Dash Lights ADFXOzymandias Riviera 0 10-18-2011 12:31 PM
Dash Lights & Battery Light LilBitEG Explorer | Explorer Sport Trac 2 09-10-2010 06:47 AM
1998 Monte Dash Lights Will No Longer Work... ermiller79 Monte Carlo 0 12-08-2009 07:35 AM
88 Camry dash lights problem mkee Camry/Camry Hybrid/Vista 6 12-08-2006 09:07 PM
90 camry dash light problem help plz vsvaz Camry/Camry Hybrid/Vista 0 04-05-2004 04:53 AM
