Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 01-25-2012, 11:59 AM
Mikelee79 Mikelee79 is offline
2000 LS v6. Missing at idle no code showing
I have a Lincoln LS 2000 model with around 140,000. The problem I have been having is with a small miss and sputter. The miss occurs at and idle and show no engine lite. So I can't ready any codes? I have replaced the three coil packs that are easier to get to but have not had the time to replace the other three. Any help would be appreciated. Thanks
Old 01-25-2012, 12:18 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 2000 LS v6. Missing at idle no code showing
Welcome to the forum!
Even if the Check Engine Light (CEL) has not come on, there could be pending codes which might help identify if the misfire is on a particular cylinder. It's certainly worth a try if you have access to a scan tool (rather than just a code reader).
Have you read the other threads here regarding the common causes of misfires on the LS V6?
-Rod
Old 01-25-2012, 01:13 PM
joegr joegr is offline
Did you also replace those three spark plugs? If not, you may be killing one or more of the new coils.
Replace all six spark plugs and the other three coils. While you have the top half of the intake off, replace the PCV valve and the elbow it attaches to.
2000 Grand am se...bad idle and stalls weis_01 Grand AM 3 09-19-2010 11:50 PM
1992 S-10 2.8L V6 Idle Craziness DaleReynolds24 S-10 6 02-22-2010 10:13 AM
P0304 code, rough idle, better since code charlie3 Contour 5 07-05-2006 12:26 PM
94 Camry has misses in low idle Code 12 Siggi 94 Camry/Camry Hybrid/Vista 1 05-11-2006 12:22 AM
2000 engine miss at idle Drives88 Taurus | Taurus Wagon 1 03-06-2006 11:57 PM
