Old 01-23-2012, 08:02 PM
sspbrad sspbrad is offline
Banned
96 Cavelier Lights not working correctly
The brights work fine like they should but when the lever is clicked to dim them they turn off. You can the pull the lever 7/8ths of the way back and the dims will turn on but only if you hold it there. Let go and they turn off. Pull it a little further and the brights turn on. Is it just a bad multi-switch?
Old 01-23-2012, 10:41 PM
Tech II Tech II is offline
Re: 96 Cavelier Lights not working correctly
Sure sounds like it.....
dash lights out & automatic lights not working bbfalls Toronado 4 10-19-2010 06:51 AM
Rear Left Running light not working johnnycodekiller '88 - '91 Civic | CRX | Wagon | Shuttlee 1 06-01-2010 01:33 AM
Four wheel drive button not working correct Gear Grinder Blazer 7 07-16-2006 09:28 PM
2002 monte carlo stock radio not working correctly. johnnnyjig Monte Carlo 3 05-02-2005 02:15 PM
Turn signals/Directionals not working correctly Chanticleer Engineering/ Technical 1 02-10-2004 06:01 PM
