Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 01-23-2012, 12:01 PM
lilblkshp lilblkshp is offline
04 ls 3.0 p 0353 please help!
i have swapped all coils and injectors from left to right. checked compression, smoked engine for vac leaks and still the problem is cylinder 5? anybody seen this before. doesnt show up as misfire on snap on solus scanner, but cylinder 5 is the main one on cylinder contribution test causing problem. gonna check fuel pressure. in meantime just seeing if someone has seen this before and can lend a little insight. thanks in advance
Old 01-23-2012, 12:33 PM
joegr joegr is offline
Re: 04 ls 3.0 p 0353 please help!
P0353 indicates an electrical fault with cylinder #3, not 5.
It will be the coil itself, the spark plug, the harness to coil 3 (often the connector at the coil), or the PCM.
Old 01-23-2012, 01:06 PM
i understand that, not getting any drops on 3. all is normal with 3 but 5 is showing the drops. got this code before swapping everything and got it again after swapping. so if it was the coil it would have moved correct? also have checked connector and performed wiggle test while running.
Old 01-23-2012, 07:26 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Did you clear the KAM or reset codes after moving the coils around? Is it a pending code, active code, or stored code?
-Rod
93 Taurus 3.0 Wagon need help with part! bgates612 Taurus | Taurus Wagon 2 02-18-2007 02:34 PM
97 3.0 overheating need help quick! 97 voyager Caravan | Voyager 7 06-04-2006 03:52 AM
1993 grand caravan 3.3 ltr..please help???? ldselder32 Caravan | Voyager 3 02-17-2006 05:00 PM
'98 3.0 won't crank..HelP hooD Sable 6 02-11-2006 02:37 AM
