Old 01-19-2012, 06:45 PM
khoover khoover is offline
wont run
i have a 91 1500, did a complete tune up on it , 2 days later it wouldnt stay running, i had to put gas in t.b. to get it started then it would stay running, after a while it would sputter then shut off, ive changed plugs, wires, cap, rotor button, coil, iac, coolant temp sensors, fuel pump, new throtle body, and it wont start up unless its warm, then it sputters, falls on its face and will die, it will start back up but run like crap for about 30 secs., also replaced fuel filter, any help would be great, its nicle and diming me
Old 01-20-2012, 02:17 AM
Schurkey Schurkey is offline
Re: wont run
What is the fuel pressure?
Does fuel spray from the injectors during cranking?
Was the old fuel filter plugged (can you easily blow through it?)
My suspicion is that the fuel pump is defective--but further testing is needed.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 01-21-2012, 05:21 PM
2000CAYukon 2000CAYukon is offline
Re: wont run
The signal to fire the injectors comes from the ignition module. Since you just changed the cap and rotor, make sure the connections at the ignition module are good and clean.
You need a special tool to check fuel pressure on the TBI trucks. Hopefully, it is just a loose connection at the ignition module.
//2000CAYukon
Old 02-06-2012, 03:18 PM
blacktiebowtie blacktiebowtie is offline
Re: wont run
the special tool can be found at most parts stores and only run you about 40bucks.... also it is a great too b/c usually it is a multi purpose tool for any fuel pressure problems on any vehicle....good tool to have.
Old 03-13-2012, 12:51 PM
Truckbuck Truckbuck is offline
Re: wont run
In case you were wondering if your fuel pump is working (What is happening with you is the same stuff that happened to me when my fuel pump died) you can just disconnect the fuel filter to the line that goes to the tank and put your key to the ON position, and if gas doesn’t come out then something is wrong with your pump, from there you can check the relay but I don’t hear those breaking very often.
good luck!
Only runs with key in the START position AMAMEK9 Eclipse Problem Diagnosis 6 03-12-2011 07:47 PM
94 grand am runs , stalls wont run, runs ?? wiseryder Grand AM 3 05-04-2004 09:49 PM
now my 84 325e wont run at all nathanL 3 Series 0 09-10-2001 01:07 AM
